Hey there.
I have authored a holiday tape by rendering an XviD in Vegas 8 and then burning it onto a DVD (as a single AVI). When I play it on my computer, it looks great. But when I play it on TV/DVD, the video jitters like crazy. When the camera pans or zooms, big square blocky artifacts are mucking about on-screen, usually where there's a big difference in colour (like the contours of a building against a sky backdrop for example). They aren't discolored, just "not where they're supposed to be".
Since I normally just watch stuff on my computer (the DVD is for my father), I never really have this problem, and since I author about one DVD every other year, I don't have enough skill to know just what the hell to do about those artifacts (and the skill I acquire during those periods, I usually forget half of).
I tried playing it on our plasma tv and also on my CRT tv. The results are nigh identical. The audio is playing correctly, in case you need to know that.
The file is encoded as 720x576 (orig size), 25 FPS, 6313kbps xvid (file size 2.47GB). I don't encode as a DVDR (which probably would be the simplest way) because the ultra cranky DVD player in our living room can't handle them. It usually plays xvids fine though.
The input files are uncompressed FFDS avi files captured in Sony Video Capture from our DV cam.
I also tried splitting it up into several smaller portions (i.e 24 avi files), but that didn't help in any way.
If I need to provide additional details just say so!
Thanks for reading![]()
Thread: Burnt XVID looks awful on DVD
A possible explanation is that some standalone players cannot handle bitrates >2-3000kbps for xvid/divx
other possibilities
http://forum.videohelp.com/topic352457.html
Ah yes, that does in fact sound familiar, now that you mention it. I remember having slightly similiar problems before. Guess I'm gonna try re-encode it.
Many don't like files larger than 2 GB in size either. I have one that refuses to play them, and one that play them up to the 2 GB mark, then stops.
That said, xvid is an awful format for TVs. The compression always does damage and the better and bigger the TV, the more noticeable it is. Why not just create a real DVD. The quality will be far higher than an Xvid file.
Like I stated in the first post, the DVD player is really cranky when it comes to homemade DVDs. It refuses to play them. It can play bought DVDs fine though.Originally Posted by guns1inger
Anyway, I fixed it thanks to poisondeathray's linkage. Thanks!
Buy good discs and make a DVD anyway....for long-term preservation at least. Players don't last forever.Originally Posted by skribby
Your present player may soon die and you'll wish you had these family memories in better quality.
Even good quality DVDs (like Taiyo Yuden and Verbatim) are cheap and easy to store.
Awful DVD playback quality
By HamishM in forum Software PlayingReplies: 7Last Post: 11th Apr 2009, 10:16 -
Converting VHS to XviD - awful quality
By Zippy1970 in forum Video ConversionReplies: 26Last Post: 11th Sep 2008, 09:22 -
quality of burned DVD is awful
By mypumpkins in forum Newbie / General discussionsReplies: 10Last Post: 16th May 2008, 15:39 -
DVD Decrypter awful slow on new computer
By zainka in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2007, 11:24 -
Truly awful quality VHS - need hints for best cleanup software to =>dvd
By Wills in forum RestorationReplies: 13Last Post: 15th May 2007, 16:02
