I like the integrated authoring/encoding approach of TMPGEnc Authoring Works 4 but I think I also will need the subject support. I take it that TMPGEnc Authoring Works 4 does not support multiple audio languages. Is there another author tool that has it all?
I looked at DVDLab which supports 8 audio and 8 subtitle... but it looks like it is lacking the integrated encoding function.
Is there another to look at that has it all?
Thanks!
Bob
You might try MuxMan. I have v0.16.6 (free) which works absolutely fine. There's also a premium and pro version. Those a only available thru some obscure procedure.
Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
Although I use Muxman every day, and although I'm convinced it's the best pure authoring program there is, it doesn't encode video or audio, which is what BobAchgill wants, for some reason. He specifically asked for some all-in-one program such as the TMPGEnc programs, but which allows for the muxing of more audio and sub tracks.
my fault...
Good Languages vs. Bad Languages?
By hech54 in forum FeedbackReplies: 8Last Post: 17th Mar 2012, 13:56 -
VCD with 2 simultaneous languages in audio.
By v-sharp in forum AudioReplies: 9Last Post: 4th Feb 2010, 06:29 -
embedd several audio languages and subtitles
By magmo in forum Blu-ray RippingReplies: 2Last Post: 30th Dec 2008, 10:51 -
SRT file not showing english? apparently theres multiple languages...
By wyteone in forum SubtitleReplies: 3Last Post: 4th Dec 2008, 09:01 -
Languages For IMGBurn?
By hech54 in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2007, 01:35
