VideoHelp.com Forum
    im looking at buying a sony HD-FX1. ive been told its a NTSC model will this cause a problem because we use PAL in australia ? or can i export the footage on final cut to the correct region it will be played in ?
    cheers jake
  2. as long as it's cheap enough it wouldn't be a bad camera. it had small 1100x900 sensors iirc, so it's not as good as newer HDV cams with true 1920x1080 sensors.
    what's your intended final output? can you live with ntsc? converting 1080 60i to pal 50i is not a great idea.
    the charger might be a problem ~ it may be 120v 60htz.
  3. Member edDV's Avatar
    cheers jake
    No easy way to convert NTSC to PAL. You would have to live with NTSC or suffer large conversion loss.
    BTW, the FX-1 will not do 24p regardless of "cinema" modes so that isn't an option.
    http://www.kiva.org/about
  1. Using Sony HDR-FX1 to Capture a Mini-DV @ 24 FPS
    By foochuck in forum Capturing
    Last Post: 11th May 2011, 17:50
  2. Sony Hi8 (PAL) pass-through to Canon (NTSC) - will this work?
    By frappefan in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 26th Dec 2010, 13:18
  3. Canon HV30 vs Sony HDR FX1
    By Cazz in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 3rd Jun 2009, 22:31
  4. After FX Keylight v DV Matte Pro Sony FX1
    By Chummy in forum Editing
    Last Post: 2nd Apr 2009, 11:33
  5. Sony HDR-FX1 firewire-input-port
    By stompinne in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 25th Feb 2008, 14:23
