Results 1 to 16 of 16
    Just upgraded to the vob2mpg pro version because I wanted the ability to extract by chapter. I open the IFO file and do a full play preview and it plays the complete chapter correctly. When I extract it to MPG there is video footage missing. This seems to occur at the point where I turn around to film another person. This footage is missing entirely. What seems to be the problem here? How do I fix this? I own a Canon DC410 camcorder. Also fixing timestamp discontinuties finishes at 28%.
    I am running Windows XP SP3. I am running .network framework 2.0 SP1. I want this to work because it will make it so much easier to send mpg files to people.
  3. Is the source disc authored by your camcorder?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Yes. It is authored and finalized by the camcorder. Windows media player and the VOB2mpg has no problem playing it, but the extraction is missing footage.
    I am uploading an image of the screen. It looks like it is not fully processing.
  6. Can you also attach your log from this run? Click 'Help' and open the 'Logs' folder.
    Dwight
    - Herm Albright
    Here is the log file. I am also attaching the file structure. It is picking up the VIDEO_TS.IFO and not the other VTS_01_0.IFO.
    ************************ SYSTEM INFORMATION ************************
    ***************************** VOB2MPG *****************************
    Title: PRO
    Version: 3.0.0040
    Executable: C:\Program Files\VOBPro\VOB2MPG.exe
    Executable size: 828 KB
    Executable size in bytes: 848467
    Executable CreationTime: 7/14/2009 10:55:42 PM
    Executable LastWriteTime: 8/14/2009 2:36:07 PM
    Executable LastAccessTime: 8/15/2009 3:50:34 AM
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 111 GB
    DeviceID: D:
    FileSystem: FAT32
    FreeSpace: 2.41 GB
    DeviceID: K:
    FileSystem: FAT32
    FreeSpace: 391 GB
    DeviceID: L:
    FileSystem: NTFS
    FreeSpace: 447 GB
    ********************* END OF SYSTEM INFORMATION ********************
    /v="L:\MaxSync\OT_MS_W_MYDOC\Videos\10-30-07\VIDEO_TS" /t=1 /c=2 /o="C:\Documents and Settings\Owner\My Documents\Seán\Jobs\Title_1_Ch_2.mpg" /sc
    22:51:21
    Extracting from Title: 1
    22:51:21 vPaths: L:\MaxSync\OT_MS_W_MYDOC\Videos\10-30-07\VIDEO_TS\VTS_01_1.VOB,
    22:51:21
    22:51:21 =============== Virtual File Details ===============
    22:51:21
    22:51:21 VTS_01_1.VOB : Length = 1003520000 (957 MB) : vPosition = 1003520000 (957 MB)
    22:51:21
    22:51:21
    22:51:21 Extracting chapter: 2...
    22:51:21 Start position: 9142272 End position: 17432576
    22:51:23 Start position: 17432576 End position: 25526272
    22:51:23 Start position: 25526272 End position: 34078720
    22:51:25 Start position: 34078720 End position: 38797312
    22:51:25 Rate: 7.90MB/s (63.17Mb/s)
    22:51:25 Extracting chapter: 2... Done.
    22:51:26 Correcting PTS values...
    /v="C:\Documents and Settings\Owner\My Documents\Videos\10-30-07\VIDEO_TS" /t=1 /c=2 /o="C:\Documents and Settings\Owner\My Documents\Videos\VOB Pro\Title_1_Ch_2.mpg" /sc
    22:59:52
    22:59:52 vPaths: C:\Documents and Settings\Owner\My Documents\Videos\10-30-07\VIDEO_TS\VTS_01_1.VOB,
    22:59:52
    22:59:52 =============== Virtual File Details ===============
    22:59:52
    22:59:52 VTS_01_1.VOB : Length = 1003520000 (957 MB) : vPosition = 1003520000 (957 MB)
    22:59:52
    22:59:52
    22:59:52 Extracting chapter: 2...
    22:59:52 Start position: 9142272 End position: 17432576
    22:59:53 Start position: 17432576 End position: 25526272
    22:59:53 Start position: 25526272 End position: 34078720
    22:59:53 Start position: 34078720 End position: 38797312
    22:59:53 Rate: 25.52MB/s (204.18Mb/s)
    22:59:53 Extracting chapter: 2... Done.
    22:59:54 Correcting PTS values...
    The 10.59 time is the last time I attempted this. I have tried it a number of times. I thought moving the file to my local hard drive instead of the external drive would make a difference.
  9. Member ChrissyBoy's Avatar
    Can you zip up and attach the .IFO files please and I will take a look?
    Just the IFO files?
  11. Member ChrissyBoy's Avatar
    Yes please in the first instance.
    Hello .. I am having the same problem as reported here. Has a resolution been found to this? If so could you provide me some direction?
    Cheers
  13. Member ChrissyBoy's Avatar
    Drop me an email and i will send you a build that should sort this.
  14. Member ChrissyBoy's Avatar
    Actually this is fixed in build: 3.0.0060
    Chrissyboy,
    You had sent me build vob2mpgpro 3.0.0050 to resolve this issue and it seems to work fine. How do I update to 3.0.0060 pro version? Thanks for all your help.
  16. Member ChrissyBoy's Avatar
    Just grab it from the registered users area...
  1. Missing footage
    By zabeel in forum Video Conversion
    Last Post: 18th Jan 2007, 04:47
  2. Interpolating missing frames in jaggy footage
    By Raga in forum Restoration
    Last Post: 7th Jun 2005, 09:23
  3. Missing footage after multiplexing
    By boing in forum Newbie / General discussions
    Last Post: 2nd Apr 2005, 10:33
  4. My VOB output is missing the last part of my video???
    By csaag in forum Authoring (DVD)
    Last Post: 13th Jun 2004, 14:07
  5. Using an already converted mpeg file as raw footage.
    By TorontoKid in forum Video Conversion
    Last Post: 18th Aug 2002, 06:10
About   Advertise   Forum   RSS Feeds   Statistics   Tools
