    Is it possible to record in 16x9 widescreen on a Pioneer DVR-520H?
    I have a 16x9 show on dvdrw. I would like to do a one touch copy to record it to hdd in the LP recording speed. But when I do it the show becomes 4:3. I even tried a higher quality recording speed like SP. Same thing. Is there a way around that? Or do I just have to deal....
    My guess ? The original recording does not have the 16:9 flag set int he video data, only in the IFO files. While this is often enough for a DVD to play the video back correctly, once the mpeg video is taken out of the context of the DVD it will revert to 4:3 display. If this is the case, you can fix it by ripping the DVD to the HDD of your PC, and using DVD Patcher to patch the headers to 16:9 display, then burning a new disc.
    Of course this is all guess work, given how little detail I have to work with.
    Read my blog here. Change England's Libel Laws - Sign Here
  3. Member drjtech's Avatar
    Why not simply rip the DVD-RW?
    -drjtech
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
    Because I am trying to fit 6 43 minute 16:9 episodes on one dvd. It's easier to use the dvd recorder than encode on my computer, but each time I do it they all become, 4:3. I wanted to see if there was a way around it...
    Come Visit the G Spot!
    I use a digital converter box (output setting is for a 16:9 TV) connected to a DVD recorder.
    The recordings are 4:3.
    Using DVD Patcher gets back the original AR.
  1. Anamorphic Widescreen DVDs...should I make 16x9 menus too?
    By oncedust in forum Authoring (DVD)
    Last Post: 17th Aug 2006, 08:54
  2. How to Create 16x9 Widescreen in Sonic MyDVD
    By 2aussies in forum Authoring (DVD)
    Last Post: 26th Jan 2005, 06:44
  3. 16x9 Recording from HD Directivo to JVC DR-M10S
    By stressbuster in forum DVD Recorders
    Last Post: 4th Jul 2004, 19:19
  4. How can I encode a 4x3 Letterbox to proper 16x9 Widescreen??
    By MoovyGuy in forum Video Conversion
    Last Post: 1st Oct 2002, 20:52
  5. All widescreen 16x9 anamorphic?
    By Jeomite in forum Video Conversion
    Last Post: 28th Nov 2001, 07:45
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
