So I encode a mkv file. The movie's name is 300 at 1080P size 8.9GB. I am trying toi resize it to 8.5GB to fit into a DL dvd.
I am told handbrake is the tool to use for this. It seems that it has 2 steps to encode. 1st one takes 1 and a half hrs to complete then there's step 2 and it take like 9 hrs to encode.
Did i do something wrong?
I followed the instructions on handbrake written here.
Results 1 to 9 of 9
Nope, that's about average.
I mean that's like almost half a day. Are you serious? -
You haven't mentioned the specs of the computer you are using for the conversion.
Originally Posted by jones24
I still stand by my suggestion in your other thread related to this that you need to just split the file in half and burn it to 2 single layer DVDs rather than waste your time re-encoding it to fit on one DL disc. -
wouldn't it be easier and faster to go buy a copy?
you don't seem to care you're openly asking for help about a pirated copy.
i simply downloaded them from the net -
Thanks guys for all your suggestions. Yes i'll probably try the other encoder linked here and yes splitting it in half makes way more sense. Then again wouldn't i need to re encode it into 2 seperate halves? Taking up more time again?
You only need to re-encode the file if its going to be authored as blu-ray and if the video isnt 1920x1080 as i mentioned in your other thread.
Handbrake encode won't start - one particular file
By Stuckster in forum Video ConversionReplies: 18Last Post: 23rd May 2013, 06:26 -
Why doesn't handbrake re-encode show video bitrate in MediaInfo?
By KushSmoka420 in forum Video ConversionReplies: 3Last Post: 26th Mar 2012, 16:55 -
Re-encode/Fix Interlaced MP4 (Film)
By Eva-Unit01 in forum EditingReplies: 48Last Post: 28th Aug 2010, 10:33 -
Does handbrake transcode or encode?
By gminnick in forum Video ConversionReplies: 6Last Post: 22nd Apr 2009, 18:36 -
shortest way to encode 5.5 hrs of avi's using tda3
By cduval04 in forum Newbie / General discussionsReplies: 4Last Post: 7th Jul 2007, 13:38
