Results 1 to 14 of 14
    I have a 2 Samsung drive system, running Vista Home Premium, and using an Asus M2N32 MB with AMD cpu.
    Original 2 drives -
    S183L
    S203B
    The original problem slow CD Audio ripping with the S183L 8X reading an audio CD using Nero DiskSpeed. The S203B reads at 28X.
    Thought it was the drive, bought a new S223L and it still reads only 8X, the S203B reads 28X. Swapped SATA ports and still the same read speeds 8X/28X for both drives.
    I downloaded the Samsung Magic Speed utility and I can't change the speed to max speed, stays at 8X.
    Am I wrong in assuming that both the S223L and S203B drives should both read at 28X, even without the Magic Speed Utility?
    What in my system would cause the S183L or S223L to read so low?
  2. DVD Ninja budz's Avatar
    What are you ripping? Commercial cds discs? Burnt cd discs?
    Your mobo is a NVIDIA chipset controller. Update the chipset drivers from the NVIDIA website and not the mobo website. Go into your mobo bios and disable RAID. Run SATA as IDE in the mobo bios as well. If this isn't done the SATA DVD Burner will not work correctly. Make sure the SATA ports the dvd burners are using are not using the RAID sata ports.
    There is 3rd party (hacked) firmware to use with your SAMSUNG drives. I own the 183L & S203B. I like using the hacked firmware to rip at faster speeds & to get better burns. Go to the SAMSUNG FORUM at CDFreaks.com to read up on hacked firmware.
    Commerical and burnt CDs.
    I downloaded the latest drivers from NVIDIA. I have RAID disabled (always was). I can't see where to force the SATAs into IDE mode. I open that SATA config for a writer and it has "extended IDE" auto or none, no IDE present. It is set to auto.
    I will look at the hack, but it is still odd that the 203B drive reads fast and the 183L or 233L drives are slow reading audio CDs only, the only real differences in these drives is the light scribe.
  4. DVD Ninja budz's Avatar
    I should have said in my earlier post to check your mobo bios first before even attempting the hacked firmware. Did take my suggestion about your mobo bios?
    NVIDIA sata chipset controllers are just one of the reasons why a SATA DVD BURNER will not work correctly. I know this because I once had a NVIDIA Asus mobo for a socket 462 AMD cpu.
    I replied in bold type to the BIOS questions in my previous reply back to you.
    I really don't see anywhere in the BIOS to force the SATAs into IDE mode. My SATA controller only has the options of Auto or NONE. RAID is enable or disable (it's disabled). If I select a SATA DVD writer in the BIOS MAIN section the options at Extended IDE are Auto or NONE (it is set at AUTO). All SATA ports are running DMA.
    Does your 183L spin up when you extract CD audio, mine does not spin up on either the 183L or the 223L, the 203B does. Sort of points to the L versions with Lightscribe locing out spin up when an Audio CD is detected.
  6. DVD Ninja budz's Avatar
    Sorry I didn't read your post correctly.
    I'll have to test out the 183L and hook up the S203B to see if it spins up. It'll have to wait until the weekend as I don't have much time in the next few days.
    Thanks,
    It is definitely stumping me. I also have an old WIN XP system which also has an Asus MB but not with the NVIDIA chipset and I'm going to try the 183L on that to see if there is any improvment with reading speed.
  8. Disgustipated TooLFooL's Avatar
    you need to change your firmware! have a look here...
    http://club.cdfreaks.com/f105/patch-...-9-new-242508/
    I am just a worthless liar,
    I am just an imbecil
    Tried downloading that patch utility from the codeguys site and Mcafee is reporting a Generic PWS trojan....
    Looking at that thread I don't see any place where you could increase the CD audio ripping speed.
    Rememeber that both my 223L and 203B read and write CD data disks and DVD data disks at a fast speed. It's just the slow CD audio extration on the 223L drive.
    Since this happens with both a 183L and 223L which has lightscribe, I'm starting to think that the Samsung L's are crippled when facing CD audio extraction
  10. Member Noahtuck's Avatar
    Mcafee is wrong and giving you a false positive.
    I'd bet any amount of money no one there is trying to get a trojan into your system
    Originally a member since 2001, LONG LIVE TARAN's!!!
  11. Disgustipated TooLFooL's Avatar
    it's a firmware hacker so i'd expect a few antivirus programs to take notice. don't worry about it!..
    i have a 223h that i unlocked a while back with this tool. i did it for the increase in data speeds, but now you got me to thinking... i do remember i did rip a few audio cd's with it. it did seem kinda slow but i didn't really think much of it at the time.. mine also has lightscribe.
    but if you wanna try the firmware, it's safe and worth a shot anyway?
    I have the patcher running, but now I don't see any hacked firmware listed for the 223L. What do I do now?
  13. Disgustipated TooLFooL's Avatar
    it's been a while, but if i remember correctly you use the patch utility to create your own hacked-firmware. you download the official firmware from samsung's website, then use the tool to create and save a new, 'hacked' version of that firmware. then you use samsung's TSDNWIN flash download tool to flash your drive with the new firmware you created.
    Sounds logical, I will try that....
  1. slow burning samsung
    By doctorrocco in forum DVD & Blu-ray Writers
    Last Post: 11th Jan 2010, 16:26
  2. Slow Rips with Pioneer DVR-A09XL
    By bryceguy in forum Mac
    Last Post: 19th Apr 2005, 14:25
  3. samsung sd-616 ripping slow
    By bingo-t in forum DVD Ripping
    Last Post: 7th Mar 2004, 07:36
  4. DVD drive rips slow.... How much does BRAND matter?
    By DVantrease in forum DVD Ripping
    Last Post: 20th Feb 2002, 11:15
  5. Playing Video Cd's (VCD) with my Samsung DVD Player 511
    By sankoo in forum Authoring (VCD/SVCD)
    Last Post: 5th Aug 2001, 07:00
About   Advertise   Forum   RSS Feeds   Statistics   Tools
