VideoHelp.com Forum
    I have a 2.5 hour long video project whose source video consists about 70% of 1440x1080i AVCHD, 20% of JPEG stills, and 10% of 1920x1080i AVCHD. It made sense to set up the project specs based on the majority content.
    The 1920x1080i AVCHD would be hard to edit in a large project on a core 2 duo PC, and has to be downsized to conform to the rest of the project anyway, so I exported the clips to a 1440x1080i MPEG2 file at 25 mbps. I then imported that clip to the primary project, completed the editing, and then created a Blu-ray disc in AVC at 21 mbps. I used Pinnacle Studio 12.1 for each operation.
    Problem: the sequences based on the native 1920x1080i video look rather blurry, worse than the native 1440x1080i, even in instances where I also transcoded the latter to HDV MPEG2.
    Is there a generic problem with converting 1920x1080i to 1440x1080i?
    Of all the intermediate codecs or conversion software available, which might be the most loss-less way to convert 1920x1080i AVCHD to a more editable format?
    Thanks for any comments or experiences.
  2. the 1920 to 1440 shouldn't be much of a problem. it's almost a direct conversion, 1440 is 1920 but with "squished" pixels, otherwise known as a widescreen flag. there are intermediate codecs like cineform neoscene or mxf you could use, but you shouldn't have to for that project. what i am surprised at is that pinnacle was able to do it at all. it has a really bad rep around here for good reason.
    Pinnacle performed the conversion, but with IQ loss. I don't know how much degradation is "normal," but would sure like to test some way to reduce it. If the reduction from 1920 to 1440 entails a tidy 0.75 ratio does that make it "slam dunk" and that any conversion program would yield more or less the same?
  4. the problem you have was most likely created by the multiple format conversions. you took 1920 avchd mpeg-4 and converted it to 1440 mpeg-2 and then back to mpeg-4 when you exported it. maybe try the project over without converting it to mpeg-2.
  1. from 1920x1080i/50 to 1280x540(4)p/25?
    By quandore in forum Editing
    Last Post: 3rd Sep 2010, 06:40
  2. Replies: 22
    Last Post: 12th Apr 2010, 13:28
  3. AVCHD Conversion
    By twfmike in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 9th Oct 2009, 12:51
  4. Replies: 1
    Last Post: 14th Jul 2009, 01:46
  5. MPEG2 Transport stream HD 1920x1080i specs Help
    By stealthProd in forum Video Conversion
    Last Post: 13th Sep 2008, 01:59
