The log file output syntax is different between dedup , getdups and tivtc, I don't know which one is preferrable. Dedup also contains a 2nd pass decimation function with timecode output, so you can create an in-sync VFR file minus the dupes
But the question was how to get mflowinter to use that log file (even a manually generated one) so you can replace the dupes, not decimate them ?
Results 61 to 67 of 67
Thread: old VHS restoration
That would be a good one
I thought that the script that i use was good-enough, but this.. would be great.
This is the script that i use, but i do a manual search for the "problematic" frames/fields:
Code:function RecoverFramePair(clip Source, int N) { # N is number of the first frame in Source that needs replacing. # Frames N and N+1(O) will be replaced. Source.trim(0,N-1) ++ CandidatesForN.trim(N-1,-1) \ ++ CandidatesForO.trim(N-1,-1) ++ Source.trim(N+2,0) } function RecoverOneFrame(clip Source, int N) { # N is number of the frame in Source that needs replacing. # Frame N will be replaced. Source.trim(0,N-1) ++ CandidatesForC.trim(N-1,-1) ++ Source.trim(N+1,0) } Source Sup = msuper() bv = manalyse(Sup, isb=true, delta=3) fv = manalyse(Sup, isb=false, delta=3) global CandidatesForN = mflowinter(sup, bv, fv, time=33.3, ml=100) global CandidatesForO = mflowinter(sup, bv, fv, time=66.7, ml=100) global CandidatesForC = mflowinter(sup, bv, fv, time=50.0, ml=100) RecoverOneFrame(7) RecoverFramePair(26) RecoverOneFrame(30) RecoverFramePair(50)
I can see delta=3 makes sense for RecoverFramePair, but shouldn't it be delta=2 for RecoverOneFrame?
Also your functions won't work for the case N=1.
You need to replace Source.Trim(0, N-1) by Source.Trim(0, -N).
If you need to recover more than two consecutive frames, see this Doom9 post (and my comments which follow it):
http://forum.doom9.org/showthread.ph...20#post1499620
Thank's Gavino, yes it should be delta=2, but i wanted to have 1 superclip and 1 set of vectors.. for all the recovering's.
Its very easy to write " rec(22), rec2(55), rec(59)... etc
Actually i don't use this script a lot, but i guess i should change something.
The way you have it now, RecoverOneFrame(22) will replace frame 22 by interpolating 50% between frames 21 and 24, instead of 23. If you really want to have just one set of vectors, you could change to use 33% here (ie use CandidatesForN instead of CandidatesForC in RecoverOneFrame), but it would be more accurate (and no great overhead) to add a second set of vectors
and use bv1 and fv1 instead of bv and fv when creating CandidatesForC.Code:bv1 = manalyse(Sup, isb=true, delta=2) fv1 = manalyse(Sup, isb=false, delta=2)
[Edited to add:]Code:global CandidatesForC = mflowinter(sup, bv1, fv1, time=50.0, ml=100)
Was this in reference to my comment about "recovering more than two consecutive frames"?
What I meant by that was if you have three (or more) bad frames together, eg want to replace 22-24 by interpolating between 21 and 25, which your functions cannot do.Last edited by Gavino; 12th May 2011 at 05:54.
Thanks Gavino, i didint have time to check my script, ill do it now and ill see what will came up.
NO, it wasn't, all i ment was that using my script it was easy for me to input the frame-numbers that needed replacing.Was this in reference to my comment about "recovering more than two consecutive frames"?
I have renamed the functions to rec(recover one frame) and rec2(recover two frames), so that ill have even less writing to do.
In example:
RecoverOneFrame(7)= rec(7)
RecoverFramePair(26)=rec2(26)
edit: i changed the delta to 2, and added another set of vectors, and i get better interpolation now.
Thank's again.Last edited by pirej; 12th May 2011 at 06:32.
Yes! YES! YES!!! I had hoped to restore my video file. I've been waiting for this moment for three years. Tomorrow I upload a piece of family film. On it two or one broken frames every five seconds and I do not know what to replace them, so that the video was correct.
I've never worked with avisynth but I will try for a result.
VHS Restoration
By Asesinato in forum RestorationReplies: 239Last Post: 25th Apr 2012, 21:11 -
old vhs restoration
By ishwinderjauhar in forum RestorationReplies: 16Last Post: 24th Sep 2011, 09:03 -
Some of my vhs restoration work
By henryperu77 in forum RestorationReplies: 3Last Post: 23rd Apr 2011, 00:24 -
VHS restoration
By degacci in forum RestorationReplies: 5Last Post: 5th May 2008, 02:02 -
VHS-C restoration
By dlarry in forum RestorationReplies: 10Last Post: 25th Sep 2007, 21:14
