  1. what's an easy and free way to do this?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    AC3 Normalizer is one option.
  3. AC3 Normalizer works but the bitrate is limited to 384kbps. How do you get full 640kbps?
    By the way, I noticed that the application uses the following Avisynth script:
    SetMemoryMax(768)
    LoadPlugin("bassAudio.dll")
    LoadPlugin("AudioLimiter.dll")
    BassAudioSource("audio.ac3").normalize(0.98)
    Also part of its internal script uses this:
    for %%a in ("*.avs") do wavi "%%a" - | aften.exe -v 0 -b 384 -readtoeof 1 - "Normalized-%%~na_1.5.ac3"
  4. Man of Steel freebird73717's Avatar
    Do it the manual way as described in soopafresh's thread which is what doctorjellybean based his ac3normalizer gui off of.
    http://forum.videohelp.com/topic317891.html
    Download the zip in soopa's first post, follow his instructions. Open the "Run_AC3gain.bat" file in notepad and change the -b 384 to -b 640
    Save the file then double click it.
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software
  5. Member Soopafresh's Avatar
    I can't recall if Aften has 640K bitrate, but it might. Give it a try and if 640 doesn't work, try 448. I've never seen a commercial DVD with AC3 audio over 448. DTS is a completely different story, however.
    "Quality is cool, but don't forget... Content is King!"
  6. I'm a Poll Super Moderator johns0's Avatar
    Avchd and blu-ray use 640kbps ac3,only 448 max for dvd.Aften will encode to 640k.
    Ben Johnson-I didnt take any stereos!
  1. Change audio volume in AVI file
    By cheerful in forum Newbie / General discussions
    Last Post: 15th Dec 2007, 09:12
  2. Replies: 3
    Last Post: 3rd Nov 2006, 09:50
  3. change volume - HOW?
    By EC in forum Audio
    Last Post: 6th Jun 2005, 02:45
  4. mp2 volume change
    By Brent212 in forum Audio
    Last Post: 28th Apr 2004, 12:02
  5. Replies: 1
    Last Post: 16th Apr 2002, 17:03
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
