VideoHelp.com Forum
  1. Member Dr_Layne's Avatar
    What would the best bitrate be to convert MPEG2 TS HDTV 1920x1080 stream to H264 at same resolution for AVCHD playback on a BD5?
    one that fits
    You are limited to about 4.37GB, so that's not going to be much running time.
    filesize=bitrate x running time
    You can use a bitrate calculator, but it's not straight forward; you have to add about 5-7% overhead for .m2ts container, and don't forget the audio bitrate
    ripbot264 does a good job of making it fit in my experience (you can lock the size and it will figure out the bitrate for you), if you don't want to do it manually, and pretty easy to use. The only thing to be aware of is some standalone players have issues with the preset GOP size (they studder on seeking ff/rw), you can add this to the commandline --keyint 24 --min-keyint 2
  3. Member Dr_Layne's Avatar
    Sorry I didn't elaborate in my original post. What I was looking for was to keep the same quality without artifacts. I think I found a good setting using Mediacoder. Setting it to the 50 mark on the quality based setting does a pretty good job of reducing the size of the file, while keeping the quality very near to the MPEG2 TS file. It also is now playable in my Sony 550 BD player without glitches.
    A_L
    open videop in megui and then creat d2v file and then start it and then it will come up another screen crop if need resize analise video if interlaced then save then choose x264 choose audio and then save choose videos size in mb then convert
  1. Replies: 2
    Last Post: 8th Nov 2011, 10:14
  2. H264 in MPEG2-PS
    By vid2me in forum Video Conversion
    Last Post: 18th Nov 2010, 14:10
  3. Convert H264 AAC to mpeg2
    By anfield7 in forum Video Conversion
    Last Post: 10th Nov 2009, 08:06
  4. H264 to MPEG2, best way ?
    By boulder in forum DVB / HDTV
    Last Post: 30th Aug 2009, 17:49
  5. Replies: 34
    Last Post: 27th Jan 2008, 14:13
