I want to connect a dvd player w/dvi output to an lcd monitor with dvi input. Is there a compatabillity problem because I am not running it trough a video card?
Thread: DVD player to LCD monitor
What DVD player has DVI-D out? Describe your cabling. Give model numbers for DVD player and LCD Monitor.Originally Posted by Ruteger1001
First set player to 480p. HDCP may be limiting higher resolutions.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
The LG LST-3510A(which I have) has DVI output but you're correct EdDV because of HDCP DVD playback it's limited to 480p, that may very well be the OPs problem.
Samsung DVD-HD931 is the player I want to use and the monitor is 17" sp7106. (sold under LG and Staples and a variety of others)
See this review.
http://reviews.cnet.com/dvd-players/...-30460851.htmlProduct summary
The good:
Excellent performance via DVI; converts DVD resolutions to 1080i and 720p; sleek styling; relatively inexpensive.
The bad:
No DVI aspect-ratio control; DVI jack won't work with non-HDCP displays.
The bottom line:
Great video and high style make this DVI deck shine, but make sure you have a compatible TV.
The 1280x1024 SP7106 doesn't seem to have HDCP. At least not in the listed specs.
So you should try 720x480p and adjust aspect ratio with custom H&V size presets.Recommends: Kiva.org - Loans that change lives.
Connect LCD PC Monitor to DVD Player
By tsloby in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2009, 11:01 -
Toshiba HD DVD player to Dell LCD 17" monitor
By jascman217 in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2009, 21:24 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / HDTVReplies: 3Last Post: 25th Sep 2007, 12:29 -
DVD player for use with LCD Monitor
By siluet in forum DVD & Blu-ray PlayersReplies: 4Last Post: 15th Aug 2007, 12:53 -
Using LCD Monitor with DVD Upconverter
By e39mofo in forum DVB / HDTVReplies: 1Last Post: 18th Jun 2007, 13:37
