i've a lot of video that it has a rare interlace..that with my megui.. i can't deinterlace of the correct form...
helpme please... i let us a previews..![]()
interlaced
deinterlaced with all deinterlace filters... less blend.. :S "fielddeinterlace :S"
please help me
Results 1 to 22 of 22
I'm afraid it is a badly resized rip. That's all I can guess. It will not be easy to deinterlace it. Did you try to use Decomb or TFM?
Tsuyoshi
If the first image is representative of your source you are not going to be able to fix it. The two fields are hopelessly commingled.
Yes. I think jagabo is right.
Tsuyoshi
The video frame size in those images appears to be 720x480. This hints that there is pixel-for-pixel mapping of the source to the snapshot. But I don't know what program you're using to produce them so I can't say for sure. I recommend you open your original video with VirtualDubMod and export a frame as PNG (Video -> Snapshot Source Frame). Then post that. VirtualDubMod will export the frame pixel-for-pixel so there will be no ambiguity about whether the fields are commingled in the source or by the software.
ok with vdm 1.5 i've this
i think that the video source is commingled
i hope your answer =)
Yes, the fields are hopelessly commingled. In a properly interlaced video one field (all the even scan lines) contains one half picture and the other field (all the odd numbered scan lines) contains the other half picture. I suspect someone converted an interlaced PAL video to NTSC and didn't resize properly.
and what solution.. can you give me..
I don't know of any solution to this problem. You'll have to find a better source.
Whoever resized and encoded the video you have screwed it up. There is no fix.Originally Posted by zikario507
wow...! it's incredible that this video couldn't fix.. well... a question..!
how can you avoid this video error?
Don't resize interlaced video with non-interlace aware resizing algorithms. Or deinterlace first.
It's also possible that a PAL source was really progressive but captured out of phase resulting in interlaced frames. That could be fixed by restoring the correct phase -- ie, recombining the fields so that pairs come from the original film frame, rather than two different film frames.
Avoid what? Avoid doing the same thing yourself? Resize in an interlace aware manner. AviSynth is perhaps the best way. For example, when doing a PAL2NTSC conversion, here's one way:Originally Posted by zikario507
AssumeTFF()
Yadif(Mode=1,Order=1)
LanczosResize(720,480)
ChangeFPS(59.94)
AssumeTFF()
SeparateFields()
SelectEvery(4,0,3)
Weave()
In the example you gave, it looks to me as if some idiot just took the PAL source and did a direct resize to NTSC, thus creating the problems you saw. When dealing with interlaced sources you have to be very careful when doing filtering of all kinds.
yes.. always i try... to prevent get a bad video..! it's the reason to create this post.. bcuz.. i downloaded that video.. that it've a bad resize & all hahaha!!!
hey manono thanks you.. for your answer.. at the same time thanks to all people that help me!!!
hey.. what deinterlace filters dont produce jaggies and part of interlace... having a dirty video!!
Well, blend deinterlacers are pretty jaggie-free. But there's so much wrong with them in other ways that I, for one, wouldn't recommend one like FieldDeinterlace at the default settings. That leave the interpolating ones and most have problems with diagonal lines, especially when the camera is in motion. In general, the better the deinterlacer the slower it is. If you're very patient, AviSynth's TempGaussMC is the way to go:
http://avisynth.org/mediawiki/TempGaussMC
Because it bobs the video (doubles the framerate), if you like you can remove every other frame with a simple SelectEven() afterwards.
Yadif is, perhaps, better than average about not leaving behind jaggies/aliasing and is quite fast as well:
http://avisynth.org/mediawiki/Extern...#Deinterlacing
And, as you can see from the list, AviSynth has many other deinterlacers also.
See this video that was posted a while back:
http://forum.videohelp.com/images/gu...mca4_tdtmm.avi
TempGaussMC_beta1
wow! is extremedely.. slow..
omg
but it give us a good result..!
do not exist any way to improve the performance of this filter? or exist another filter that it give us a good result too but more faster than last!
Get a faster computer? Maybe Avisynth MT version on a multicore CPU. I haven't tried it.Originally Posted by zikario507
I don't know of anything that's nearly as good.Originally Posted by zikario507
i've an amd athlon x2 7550 BE.. @2.7Ghz.. 2Gb!
but.. i can't use avisynth mt version.. :S bcuz.. it give me an error that say you need avisynth 2.6? or 2.5.6 mod :S
ok.. i fix my problem but.. it doesnt give me a better performance!!
Did you enable the MT option? I'm not even sure TempGaussMC works with it. Never tried.
later...
I just tried the AviSynth MT version linked from this post:
http://forum.videohelp.com/topic371557.html#1993934
I added SetMtMode(4) to the top of my script (I have a quad core CPU). Processing speed improved by about 2x when using TempGaussMC_beta1().
Weird problem when using deinterlace filter from VirtualdubMod...
By artyjeffrey in forum RestorationReplies: 12Last Post: 22nd Apr 2010, 10:11 -
Deinterlace?
By ZedsDead in forum Video ConversionReplies: 6Last Post: 14th Mar 2010, 23:21 -
AVCHD PAFF Deinterlace / Video time length problem
By tat2jr1 in forum Video ConversionReplies: 4Last Post: 24th Jul 2009, 03:58 -
Tv Tuner (deinterlace) Problem
By harry29 in forum ComputerReplies: 1Last Post: 5th Mar 2009, 12:17 -
Alparysoft Deinterlace for AVISynth problem
By _migz_ in forum Video ConversionReplies: 5Last Post: 3rd Aug 2007, 07:54
that with my
