Delete the post.
Results 1 to 20 of 20
Originally Posted by charmed94
You must copy FFmpeg to that subfolder.
If FFmpeg is there, it is recognized automatically.
"Destination" is the path you have to give to where you want the output aac written. -
Perhaps you mix up the durations of the PAL and NTSC versions.
If the PAL video is 21.08, then audio is probably streched to 22.02 at the PAL/NTSC conversion.
If the NTSC movie is 22.15 and the converted audio 22.02, you could be dealing with two different versions of the movie (the PAL and the NTSC). Then I can be hard to get the audio in sync even if it's converted to NTSC properly.
EDIT: Just mux them and see what it does. BTW: the duration reported by MPC perfectly fits the NTSC video duration.
Quick easy way to convert DVD subs from 25fps to 23.976fps?
By nick1977 in forum SubtitleReplies: 19Last Post: 22nd Feb 2015, 17:36 -
25fps-source Ac3 to 23.976fps
By Lastman369 in forum AudioReplies: 47Last Post: 26th Sep 2014, 02:19 -
[MKV] 25fps to 23.976fps? Tried and failed. Help!
By lag in forum Newbie / General discussionsReplies: 15Last Post: 20th Aug 2014, 12:27 -
NTSC HDTV is usually broadcast at 23.976fps, yes?
By Gew in forum Newbie / General discussionsReplies: 38Last Post: 21st Feb 2010, 18:56 -
converting 25fps to 23.976fps
By pannivas in forum AudioReplies: 1Last Post: 3rd Aug 2007, 16:49
