VideoHelp.com Forum
    It plays fine on my pc but will not work in my ps3 burned to a disc
    When I try to fix it with the AVI fixers they say that there is nothing wrong with it.
    When I try to reencode using autoGK virtualdub stops the encoding near the end and says that the source resolution is wrong.
    How do I fix this file?
    Thanks[/s]
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Not that familiar with the PS3 video requirements, but that would be the first thing to find out. Then re-encode your video to those specifications. I would drop the file into MediaInfo or Gspot and see what resolution, etc., it presently is. Then convert that to something your PS3 can accept.
    That error can also be caused by a odd resolution. Most times you want the vertical and horizontal resolution to be divisible by two, four, or eight or sixteen, depending on the codec used. Odd numbers will generally cause problems.
    Playing on a PC doesn't mean much of anything. Some players like VLC can play a corrupted file or one with missing frames and you may not notice. But try to encode or play that file on a set top player and it won't work most times.
    In Virtualdub it gives me this error when I try to fix the resolution:
    Video compression error:The source image format is not acceptable. (error code-2)
    As redwudz said - drop the file into MediaInfo or Gspot to see what the file actually is.
    352X256 @29.970 mpeg4 xvid
  6. VH Wanderer Ai Haibara's Avatar
    We're going to need more information than that, actually. If you use GSpot, load the video, then take a screenshot of the entire window and post it here. You can blank out the file and pathnames, if you want. If you're using MediaInfo, switch to Tree View. Copy all of the information given, then paste it into a post, here.
    Standalone players are a LOT more picky about the videos they will or won't play, than a PC. The PS3 takes it a little further, reportedly, and is even more picky about Xvid AVIs than DivX AVIs. I haven't tested that many AVIs with the PS3, so I couldn't say for sure.
  1. Replies: 5
    Last Post: 6th Jan 2010, 09:13
  2. Trouble with AVI files
    By Warhammer in forum Blu-ray Ripping
    Last Post: 24th Sep 2008, 14:25
  3. AVI trouble
    By AirborneRanger in forum Newbie / General discussions
    Last Post: 19th Aug 2008, 00:02
  4. Movies in AVI - Trouble
    By Jomapil in forum Newbie / General discussions
    Last Post: 4th Apr 2008, 22:27
  5. Trouble with AVI in ConvertX
    By Squid_uk in forum Newbie / General discussions
    Last Post: 30th Jan 2008, 11:07
