Canon makes a waterproof case for underwater video recording, Canon WP-V1. It says that it is designed for the HF-20 and HF-200 HD camcorders. I own an earlier version of the HF-20, the HF-10. The main difference that I notice is that my version has a 16 GB internal flash memory drive, and the HF-20 has a 32 GB drive. There is also some difference in the sensor, etc.
My question is whether the WP-V1 will work with the HF-10? Does anybody have any thoughts?
Thanks!
Thread: Canon WP-V1
Download the manuals for the housing and both the cams. Look at the physical specs--compare dimensions, placement of controls, etc. That will determine whether the housing will work with it.
My guess is it will.
Of course, to be on the safe side, I would suggest you go to a local/regional dealer of Canon stuff and try it on for size first.
Canon S2 1S
By tarzan54 in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 28th Feb 2012, 07:57 -
Canon T3i
By Video Head in forum Camcorders (DV/HDV/AVCHD)Replies: 28Last Post: 10th Apr 2011, 09:10 -
Difference between Canon Vixia HF-20 vs Canon HF-S20?
By Wink in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 20th Nov 2010, 16:46 -
Canon Rebel xti + Canon HV30 vs. Canon Rebel T2i
By assman24 in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 17th Jun 2010, 11:47 -
Canon XH-A1 or Canon XH-A1S?
By ProducerHarley in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2009, 22:34
Statistics
Newest guides
Latest tool updates
New media comments
