This is a tough one and I have tried to debug to the best of my abilities but here i am:
here's my ffmpeg cmd line
-y -i "C:\\Documents and Settings\\brandong\\Desktop\\MMAMethod\\Movie.m4v\ " -ar 44100 -qscale 11 -bufsize 10000k -s 1280x720 -r 20 \"C:\\Net Projects\\SVN\\IntegratedAlgorithmics\\src\\MediaA dmin\\MediaAdmin\\bin\\Debug\\Temp\\5b163b60-8093-48a3-9ff8-b869514498e2.flv\
here's my assumptions for the above
since i am converting to an flv from a h264 it will down convert it to h263, if not this may the root of my issue and I should force a vcodec, although i am unsure of the vcodec for flv h263.
Lets start with that and then i will expand upon any other issues[/code]
here's a breakdown of my input video
General
Complete name : C:\Documents and Settings\brandong\Desktop\MMAMethod\Americana- head control cc.264.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 15.2 MiB
Duration : 1mn 52s
Overall bit rate : 1 134 Kbps
Encoded date : UTC 2009-08-06 01:52:26
Tagged date : UTC 2009-08-06 02:19:51
Writing library : Apple QuickTime
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : avc1
Duration : 1mn 52s
Bit rate mode : Variable
Bit rate : 619 Kbps
Width : 720 pixels
Height : 360 pixels
Display aspect ratio : 2.000
Frame rate mode : Constant
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.080
Stream size : 8.29 MiB (55%)
Encoded date : UTC 2009-08-06 02:19:37
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 1mn 52s
Bit rate mode : Constant
Bit rate : 512 Kbps
Channel(s) : 1 channel
Sampling rate : 32.0 KHz
Resolution : 16 bits
Stream size : 6.85 MiB (45%)
Menu
Format : TimeCode
Encoded_Date : UTC 2009-08-06 02:19:51
Tagged_Date : UTC 2009-08-06 02:19:51
This is kinda driving Me crazy and I apologize in advance for the verboseness of post
I am trying to convert TO FLV and seem to be having some issues with streaming and or playing properly
I have used mp4box and qt-start
heres an input file that works once i have converted
General
Complete name : C:\Documents and Settings\brandong\Desktop\MMAMethod\Movie.m4v
Format : MPEG-4
Codec ID : M4V
File size : 2.19 MiB
Duration : 22s 200ms
Overall bit rate : 828 Kbps
Encoded date : UTC 2008-09-16 22:23:51
Tagged date : UTC 2008-09-16 22:23:51
Video
Format : AVC
Format profile : Baseline@L2.1
Codec ID : avc1
Bit rate : 827 Kbps
Width : 480 pixels
Height : 270 pixels
Display aspect ratio : 16/9
Frame rate : 30.000 fps
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.213
Stream size : 2.19 MiB (100%)
Language : English
Tagged date : UTC 2009-08-06 18:04:58
heres the output of that file once i have converted to flv
General
Complete name : C:\Documents and Settings\brandong\Desktop\MMAMethod\7669dd16-0d6f-43ed-abdd-14b20298e0f1.flv
Format : Flash Video
File size : 830 KiB
Overall bit rate : 306 Kbps
Video
Format : H.263
Bit rate : 195 Kbps
Width : 480 pixels
Height : 270 pixels
Bits/(Pixel*Frame) : 0.050
Stream size : 529 KiB (64%)
and here's one that doesnt work
General
Complete name : C:\Documents and Settings\brandong\Desktop\MMAMethod\trailers\90828 471.mov
Format : MPEG-4
Codec ID : qt
File size : 39.2 MiB
Duration : 51s 776ms
Overall bit rate : 6 350 Kbps
Movie name : Saw VI - Trailer 1A
Performer : Yahoo! Movies
Encoded date : UTC 2009-08-05 18:59:16
Tagged date : UTC 2009-08-05 18:59:17
Copyright : © 2009, Lionsgate
Video
Format : AVC
Format profile : Main@L3.1
Codec ID : avc1
Duration : 51s 760ms
Bit rate : 6 158 Kbps
Width : 1 280 pixels
Height : 720 pixels
Frame rate : 23.976 fps
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.279
Stream size : 38.0 MiB (97%)
Encoded date : UTC 2009-08-05 18:22:07
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Bit rate : 188 Kbps
Nominal bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Stream size : 1.16 MiB (3%)
my ffmpeg args are fairly simple
-y -i "{1}" -vcodec flv -ar 44100 -qscale 10 -bufsize 20000k "{2}"
aNY HELP WOULD BE GREATLY APPRECIATED
streaming live to red5
By jackyr in forum Video StreamingReplies: 0Last Post: 11th Dec 2011, 11:15 -
Issues going from AVI to FLV for streaming video
By Website Captain in forum Video ConversionReplies: 1Last Post: 29th Dec 2009, 18:10 -
Problem converting mov to flv with ffmpeg
By zigune in forum Video ConversionReplies: 8Last Post: 15th Jul 2009, 02:03 -
Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?
By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 22:11 -
Need a little help here (wmv/mov to flv with ffmpeg)
By yeauxyo in forum Video ConversionReplies: 1Last Post: 9th Jul 2007, 23:08
Statistics
Newest guides
Latest tool updates
New media comments
