  1. Member Ogilvy's Avatar
    Hi, I'm trying to figure out why the vlc player won't play .flv files encoded with H264, when it handles everything else. I've read somewhere that it's dependant on ffmpeg. Is this true? Running Ubuntu Hardy with what I think are latest versions of vlc etc.....
    mplayer - 2:1.0~rc3svn29325-0hardy1
    ffmpeg....3:0.cvs 20070307-5ubuntu7.3+medibuntu1
    vlc....0.9.9a
    mencoder...2:1.0~rc3svn29325-0hardy1
    The Mplayer plays these files but it's not my player of choice.
    Vlc output for .flv file with h264....
    „No suitable decoder module:
    VLC does not support the audio or video format "undf". Unfortunately there is no way for you to fix this.
    VLC does not support the audio or video format "undf". Unfortunately there is no way for you to fix this“.
    Has anybody found a solution for this....or any help....tearing the hair out! Obliged
  2. Get Slack disturbed1's Avatar
    Did you compile vlc or install from some repo? Vlc is upto 1.0.1, which includes security patches. You should update if you can.
    You can do mplayer -identify file.flv to see what codec mplayer identifies it as.
    Check that you have libx264 installed. If you installed libavcodec, libavformat, libavutil, libpostproc, and libswscale from medibuntu it will pull in all the needed libs.
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
  1. No time shown in flv movies in VLC player or webpage
    By RobRocket in forum Video Conversion
    Last Post: 19th Aug 2009, 05:39
  2. VLC / KMPlayer / MediaPlayer Classic... h264 Decoding
    By triptych in forum Newbie / General discussions
    Last Post: 2nd Jul 2009, 13:17
  3. VLC player: can someone recompile w/ mplayers h264 codec ?
    By vhelp in forum Newbie / General discussions
    Last Post: 1st Feb 2009, 21:40
  4. MediaInfo Fails To Read H264 Encoded File
    By seemyvid in forum Video Conversion
    Last Post: 19th Dec 2006, 20:41
  5. H264 encoded movies no longer function with PSP system 2.70
    By dasmus in forum ffmpegX general discussion
    Last Post: 3rd Jul 2006, 01:33
About   Advertise   Forum   RSS Feeds   Statistics   Tools
