Issue: How to extract a JPEG file out of a SWF file?
I ran this command
ffmpeg -itsoffset -4 -i 241231.swf -vcodec mjpeg -vframes 1 -an -f rawvideo -s 320x240 test.jpg
And it gave the following error:-
FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --enable-gpl --enable-postproc --enable-swscale --enable-avfilt
er --enable-avfilter-lavf --enable-pthreads --enable-avisynth --enable-libfaac -
-enable-libfaad --enable-libmp3lame --enable-libspeex --enable-libtheora --enabl
e-libvorbis --enable-libxvid --enable-libx264 --enable-memalign-hack
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 0 / 52.20. 0
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 4. 0 / 0. 4. 0
libswscale 0. 7. 1 / 0. 7. 1
libpostproc 51. 2. 0 / 51. 2. 0
built on Mar 16 2009 16:09:18, gcc: 4.2.4 [Sherpya]
Input #0, swf, from '241231.swf':
Duration: 00:00:32.66, bitrate: 31 kb/s
Stream #0.0: Audio: mp3, 22050 Hz, mono, s16, 32 kb/s
Output #0, rawvideo, to 'test.jpg':
Output file #0 does not contain any stream
Or sometimes it gives Compressed SWF format not supported error.
Please provide the solution for the same. At every post, there is only the issue and not the solution for it.
Please note that this forum is for users of ffmpegX, the Mac OS X GUI for ffmpeg, mencoder and mpeg2enc. There are more appropriate forums for command line ffmpeg users.
Your Profile suggests that you are not running Mac OS X. Perhaps you can ask a moderator to move your topic to some other, better suited, forum on Videohelp.com.
Depending on the number of JPEGs you want and the number of SWF files you have, consider a low complexity solution like a screen capture. Or else consider one of the many SWF editors.Originally Posted by marora26
can ffmpeg convert SWF to FLV ?
By yair2008 in forum Video ConversionReplies: 3Last Post: 1st Dec 2008, 19:44 -
convert AVI to swf
By theewizard in forum Video ConversionReplies: 2Last Post: 23rd Jan 2008, 21:59 -
How to convert swf to avi ??
By yunakokimama in forum Newbie / General discussionsReplies: 5Last Post: 6th Nov 2007, 02:20 -
How to convert dv to swf
By Redi@VideoHelp in forum MacReplies: 8Last Post: 3rd Aug 2007, 11:41
Statistics
Newest guides
Latest tool updates
New media comments
