VideoHelp.com Forum
    Please help. I have been using BD rebuilder for about 4 weeks now and have backed up 20 Blu ray movies, but over the last 2 days i have not been able to get anything to copy. I keep getting a message saying that multiplexing has failed at the end of phase 2. I have tried Body of lies, Hellboy2, serenity, Babalon A.D & Day after toworrow. I am running the latest version of BD rebuilder 0.26 and am ripping the Blu rays to HD with ANYDVD HD (latest version). Any help would be great.
  2. Member fritzi93's Avatar
    Mind you, BDRB is beta. I've found it to be a little touchy. :P
    Anyway, *most* of the trouble I had came down to installing/uninstalling similar programs. What fixed everything for me was a simple re-install of Haali splitter and ffdshow. You shouldn't have to re-install Avisynth. Configure h264 to use ffmpeg-mt (multi-thread) and enable MPEG-2 decoding in ffdshow. (I presume you already have DirectVobSub?)
    I had to do the above each time I installed/uninstalled: AVCHDCoder; D2MP; ClownBD; and MakeMKV. Have you changed any hardware or software lately?
    Note that I only have ffdshow, Haali, DirectVobSub and a very few other codecs on my computer, so the problem doesn't arise from a multiplicity of filters or codecs. I would recommend others to do the same.
    So give it a try, hope it works for you. Good luck.
    Pull! Bang! Darn!
    Many thanks. Worked a treat
  4. Member fritzi93's Avatar
    We appreciate it when people report back on whether advice given was any good. So thank YOU.
    Pull! Bang! Darn!
  1. Problems with BD Rebuilder
    By pandemonium in forum Blu-ray Ripping
    Last Post: 22nd Nov 2011, 03:33
  2. BD Rebuilder Movie Only Problems!
    By kings322 in forum Blu-ray Ripping
    Last Post: 1st Jun 2010, 05:11
  3. BD Rebuilder problems.
    Last Post: 19th May 2010, 21:20
  4. BD-Rebuilder problems
    By Squeez in forum Blu-ray Ripping
    Last Post: 4th May 2010, 17:15
  5. BD Rebuilder Problems
    By ronorkis in forum Blu-ray Ripping
    Last Post: 18th Jul 2009, 13:32
