Hi,
I am new to the forum, I kind a started using ffmpegX with my Mac so far. This evening I had the problem, that the conversion of a VOB File (Part of a VIDEO-TS folder) stops at 9.50 min (the original lenght is 18 mins).
If I try to open the VIDEO-TS-Folder with ffmpegX I cannot preview it and also cannot decode it. The Conversion-process only works with the VOB-Files in the folder.
Does anyone have a clue? Did I install ffmpegX correct?
Thanks!
Sven![]()
Carpe Diem!
Some engines seem to work better than others on VOB files. Are you willing to try to convert to a DivX file? You'll likely get better results. There is probably a time-code issue on the DVD rip.
Possibly you ripped a DVD that had deliberate bad sectors as copy protection. Or possibly the file had a corrupt MPEG GOP which cannot be parsed. Or there is a timecode break that needs fixing.Originally Posted by Fly Eagle
The [Play]-button should be able to let mplayer play the VIDEO_TS folder. The upper-right [Preview]-button is only to preview the conversion output while the conversion is still in progress.Originally Posted by Fly Eagle
The mencoder engine is able to convert directly from VIDEO_TS folders. So give it a try with the H.264 mencoder preset (note that its output isn't iPod compatible).Originally Posted by Fly Eagle
If you want to convert with any ffmpeg preset, then first join the VOBs of the Video Title Set that you want, into a single big VOB file.
several VOB files to single file (mp4)
By smondal29 in forum DVD RippingReplies: 1Last Post: 24th Jun 2011, 03:23 -
Split mp4 file into 10 minutes parts in order to upload on youtube
By vitcon in forum ComputerReplies: 4Last Post: 11th Mar 2011, 13:30 -
ini file conversion to mp4
By pacific77 in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2010, 14:02 -
Convert VOB file to MP4 (PSP)
By HunterD in forum Video ConversionReplies: 4Last Post: 5th Mar 2010, 02:39 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
Statistics
Newest guides
Latest tool updates
New media comments
