I am definitely a Newbie, and I hope this is the right place to post. I recently downloaded Avidemux 2.5, and I am trying to combine two .wmv files. The video of the combined file looks great, but the audio of the first .wmv file repeats on the second file. I have used the basic 'copy' video and audio settings, plus several combinations, but no luck. Anyone know how to fix this problem?
Thanks....Weatherman19
Thread: Avidemux audio problem....
I would try join using asfbin and see if it works better.
And yep, it's the right place to post and welcome to our forums.
I just downloaded asfbin GUI 1.5. It is almost all grayed out and I can't get it to do anything.
Did you specify the directory ? In the top right it says "select files from", press the "..." and specify the location, then highlight the files you want and press the "<---"Originally Posted by weatherman19
I can get it to show the correct directory/folder. But I can not get it to list anything, including video files, in that directory to select from. Just about everything in the AstBin window is gray.
Try a different version, there is a list of older ones
http://www.videohelp.com/tools/AsfBi...sions#download
e.g.
http://www.videohelp.com/download/as...n1.5.0.557.zip
avidemux audio out-of-sync problem
By scarlac in forum Video ConversionReplies: 3Last Post: 20th Sep 2010, 11:37 -
avidemux audio problem
By scarlac in forum MacReplies: 3Last Post: 8th Sep 2010, 03:08 -
Avidemux - DVD/VOB file to MP4/MKV - Audio problem
By prabath_fun in forum Video ConversionReplies: 0Last Post: 7th Sep 2010, 10:32 -
avidemux audio shift problem
By allenn in forum Video ConversionReplies: 0Last Post: 16th Dec 2009, 21:44 -
Audio shift problem in Avidemux
By sir_ken in forum DVD RippingReplies: 3Last Post: 18th Sep 2009, 12:25
