I need some help from the experts please
I don't own a receiver but would like to use headphones that allow me to have full control over the volume perhaps with TV remote or ETC.
Crappy headphones with volume control will not do here.
I currently have headphones connected with a cable female stereo to composite to my plasma hdtv but have no control of volume cannot adjust.
What is the best way to get volume control for my situation?
is the only way to drop $300 on a good receiver?
Does popcorn hour c-200 have a headphone jack and can control volume with remote? if so id rather buy that then a receiver at this time.
Thanks in advance for the help.
Results 1 to 9 of 9
Thread: Popcorn hour headphone
It sounds to me like you are using an RCA monitor output with your headphones. Doesn't your TV have a headphone output? (Typically a 1/8th inch stereo pin plug.) The volume of that output is usually controlled by the TV. If not, you could use decent wireless headphones with their own volume controls.Originally Posted by B2K24
Edit: corrected by Baldrick
I bought the WD HDTV media center because of this thread, now i want to have headphone control with this device for when i'm watching media files when my kids are asleep. If you can't be of any help Supreme2k, then don't bother to post.Originally Posted by Supreme2k
My question relates to this device and it's usage and is far better than your non productive spam.
I am merely trying to get some ideas about volume control relating to this device.
Thanks for the wireless headphones idea i will look into that. Can you link me to anything you recommend?
I will also check my tv for stereo plugin. Thanks for the help.
I haven't used the Sennhieser wireless headphones but their wired headphones are very good. Something like this will probably be adequate:Originally Posted by B2K24
http://www.amazon.com/Sennheiser-RS1...dp/B0001FTVEK/
There are other models too. I had a chance to hear some Sony wireless headphones a few years ago. I didn't do any serious listening (I was just seeing how much interference I got moving around the house) but they sounded ok.
B2K24: PLease don't hijack topics. Moved you to your own topic. You can change the subject title by editing your first post.
Supreme2k: Please just report the post.
No problem.
You can use an "in-line" volume control extension like this 1 from from Radio Shack w/ your choice of quality headphones for $9.99USDOriginally Posted by B2K24
http://www.radioshack.com/product/in...ductId=2552561
or this Koss from Amazon.com $7.74USD
http://www.amazon.com/Koss-155954-VC.../dp/B00001P4XH
google around if you want a "high-end" volume control
edit: I found it for you, Sennheiser volume control $32USD
http://www.amazon.com/Sennheiser-HZR...9353397&sr=8-5
ocgw
peaceAthlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
http://forum.videohelp.com/topic368691.html
M2ts files on Popcorn hour?
By bagmand22 in forum Blu-ray RippingReplies: 3Last Post: 3rd Dec 2009, 05:27 -
Do you prefer fresh popped popcorn or day old popcorn?
By yoda313 in forum PollsReplies: 20Last Post: 14th Jul 2009, 23:16 -
Encode DV video to play on Popcorn Hour
By vidarmas in forum Video ConversionReplies: 6Last Post: 8th Jun 2009, 13:10 -
Western Digital HD TV Player or Popcorn Hour A110?
By live4fun in forum DVD & Blu-ray PlayersReplies: 9Last Post: 6th Feb 2009, 22:42 -
Popcorn Hour
By TheRubster in forum Newbie / General discussionsReplies: 9Last Post: 13th Nov 2008, 16:10
