VideoHelp.com Forum
    Hey There,
    I've been using HDVSplit for months with Adobe Premier Pro, because PPro doesn't have scene d etect in HD. Now suddenly the HDVSplit is dropping frames, and the files are all messed up. I know it's the HDVSplit, because I can capture the footage (without the scene detect) with Premier pro with no dropped frames. What can I do about it?
    Boadicea7
  2. Member edDV's Avatar
    Originally Posted by Boadicea7
    Hey There,
    Boadicea7
    First avoid preview. That alone can cause frame drops. Transfer without preview. Monitor on the camcorder.
    http://www.kiva.org/about
    But I don't use the preview function in HDVSplit.
    Boadicea7
  4. Member edDV's Avatar
    Use Task Manager (or Resource Monitor in Vista).
    When I run it here, there is no affect on CPU or memory. Only the hard drive gets lightly exercised at ~4MB/s.
    If your hard drive is near full or highly fragmented, you may get drops.
    Best to capture to a drive other than the OS drive. The OS sometimes takes priority and can steal the drive.
  5. capture without scene detect. use scene detect on the captured file afterward.
  1. Dropping frames on New PC
    By beammeup in forum Capturing
    Last Post: 16th Apr 2012, 11:36
  2. Replies: 15
    Last Post: 12th May 2011, 21:15
  3. Replies: 16
    Last Post: 30th Nov 2009, 06:20
  4. WinDV dropping frames
    By 2Bdecided in forum Capturing
    Last Post: 17th Oct 2009, 03:23
  5. Dropping frames while converting to .dv
    By Huntr777 in forum Mac
    Last Post: 10th Jun 2009, 16:19
