Hello,
I have always created my dvd but left it until later to burn of which i then used Nero.
I thought i would give this software ago with using it to burn the dvd after it had been created & not use Nero.
I have added my assets etc of which just went over the limit so i selected Autofit which brought it back to 4.37Gb
I have installed Imgburn v2.5.0.0 and have changed my settings for it to be used in burning,i have also selected the exe path withing the settings.
The software created the dvd no problem but when it opened up Imgburn to start burning a message pops up to say not enough space on disc to burn ?
I have supplied a photo of the image.
If i use the same Ts folder and burn in Nero all is well,i assumed that as i had selected the Autofit button all would be ok but not so.
Please advise how or what i need to change so the Imgburn can do its job without the message etc popping up.
nero is either burning to the end of the disc and leaving off what doesn't fit or re-encoding it to a smaller size.
you need to make your disc image smaller to begin with.
I thought i was making the image smaller,after i had put assetts,background,music etc i clicked on autofit.
I then assume autofit would make it small enough to fit on a dvd.
I will try it again and see but it that not the point of autoifit,like you say nero may be at fault so i will look at it thanks.
try using a size like 4.25 gb or 4,375 mb to leave a little bit of error room. autofit may not work everytime....
Have a look at -
http://forum.videohelp.com/topic285423.html
and
http://forum.videohelp.com/topic305078.html
Good Luck!
IMG BURN windows error
By dereal in forum DVD RippingReplies: 1Last Post: 22nd Dec 2011, 16:36 -
DVD Shrink and IMG Burn
By tcory in forum DVD & Blu-ray WritersReplies: 10Last Post: 9th Jan 2011, 14:25 -
IMG Burn says - File too large!
By orfajackson in forum Newbie / General discussionsReplies: 6Last Post: 26th Jul 2009, 13:41 -
I/O Error in IMG Burn - Help!
By msdker in forum Newbie / General discussionsReplies: 7Last Post: 21st May 2008, 23:11 -
Which is best to burn - img, iso or video_ts
By dynamique in forum Authoring (DVD)Replies: 10Last Post: 29th Sep 2007, 14:13
