VideoHelp.com Forum
  1. I'm sure this an obvious answer, but whats the deal with their still being analog stations broadcasting? I was setting up my TV at the new place, and since I ditched cable I had to scan for channels. There is no way to make the TV skip analog channel search, so I had it go ahead and do it. Once complete, I had all the digital channels and 2 analog channels as well. I live out outside of Indianapolis, and it appears that our NBC affiliate which use to broadcast on Ch. 13 is broadcasting a news/weather station that also shows some cartoons on Saturdays mornings still. There also seems to be a Spanish language station still broadcasting. What gives?
    This plan is so bad, it must be one of ours.
    Many analog stations are exempt from the digital switch for various reasons.
    Low-power stations were exempt from the June 12, 2009 deadline. They must switch in a few years, but were given extra time because they don't have the same financial resouces as full-power stations.
    (Edited to correct a spelling error.)
  4. Member edDV's Avatar
    It may be a rural translator. They can operate until 2012.
    Some stations that don't interfere are doing "Nightlight" service. These are mostly Ch2-6.
    Which analog channel numbers are you getting?
    http://www.kiva.org/about
  5. It's channels 52 and 27. They are both fairly weak, but almost watchable.
  6. Member edDV's Avatar
    27 in Indianapolis is ION WIPX-DT (virtual 63.1). This should be digital.
    Also on 27 is WSOT-LP, a low power analog translator in Marion, IN. They have a construction permit to convert to digital.
    52 is no longer in the UHF TV band. I see no stations or translators listed near Indianapolis. It may be a rural translator.
  1. 2 TV's, one antenna ; different stations?!?!?!
    By HDFreeV in forum DVB / HDTV
    Last Post: 2nd Feb 2010, 13:36
  2. Standard Cable w/o STB thru VCR will allow digital stations?
    By rcholden in forum Newbie / General discussions
    Last Post: 8th Nov 2009, 20:55
  3. Panasonic DMR-E80H not able to record sub stations
    By chrisincent in forum Newbie / General discussions
    Last Post: 15th Apr 2009, 12:57
  4. How do analog repeater stations get their signal?
    By cal_tony in forum DVB / HDTV
    Last Post: 22nd Feb 2009, 12:04
  5. Replies: 2
    Last Post: 7th Oct 2008, 09:11
