Hello,
I try to convert a file with screen size 720x304 from AVI (divx) to MP4. I set the Output size in the right side of the Video options tab to 720x304, the ratio to 2.35:1, and the framerate to 25 (PAL).
I use the MPEG4[.MP4] (ffmpegx) encoder. The conversion works fine unless the output size is always 533x400.
What am I doing wrong?
Thanks in advance,
Tom
Log:
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Sat Aug 1 16:13:04 CEST 2009
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Input #0, avi, from '/Users/user/Movies/movie.avi':
Duration: 01:28:59.1, start: 0.000000, bitrate: 1107 kb/s
Stream #0.0, 25.00 fps(r): Video: mpeg4, yuv420p, 720x304
Stream #0.1: Audio: mp2, 48000 Hz, stereo, 128 kb/s
Output #0, mp4, to '/Users/user/Movies/movie.avi.ff.mp4':
Stream #0.0, 25.00 fps(c): Video: mpeg4, yuv420p, 720x304, q=2-9, 1617 kb/s
Stream #0.1: Audio: aac, 48000 Hz, stereo, 96 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
bench: utime=784.024s
video:1053425kB audio:62560kB global headers:0kB muxing overhead 0.279503%
Encoding completed on Sat Aug 1 16:25:20 CEST 2009
I don't get the error when I try it. What is your input source? A VIDEO_TS folder? If so, you may give Handbrake a try.
I can replicate this issue. The output resolution is 720x304 as specified (as MediaInfo Mac will confirm), but some display aspect ratio flag isn't set properly, so that the player software stretches the video to a 4:3 aspect ratio.
If I remember correctly, this will happen for every conversion to .mp4 using this engine, when the target isn't exactly 16:9 or 4:3. So for 2.35:1 output, this problem comes up, unfortunately.
It could be that the ffmpeg team has fixed this already, but ffmpegX has to be updated to work with that. I'm not holding my breath...
You can change the display aspect ratio in QuickTime Pro, but you'll end up with a .mov container.
What is really needed here, is an MP4 toolbox to change (correct) just the display aspect ratio, without altering the rest of the file. Anyone know of such a piece of software?
Hi Case,
thanks for the analysis. Importing the file into iTunes did the job.
Best regards,
Tom
Case, when are you going to take over development of ffmpegx????Originally Posted by Case
Hehe, I haven't programmed software in a very long time, and never on Mac OS. It would take a lot of research before I even can write a first line of code. Not worth the effort, as long as some current software does what I need. Besides, major has never hinted at handing over any source code to anyone.Originally Posted by dizzie
Thanks for the vote of confidence, though.
MP4Box can do this by setting the pixel aspect ratio to 1:1.
http://forum.videohelp.com/threads/3...=1#post1970798
Converting TS to MKV - video is shaky and seek doesn't work
By Scorpick in forum Video ConversionReplies: 11Last Post: 5th Mar 2012, 18:11 -
After Encoding Handbrake gives Error and Output video doesn't work
By ConverterCrazy in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2011, 08:36 -
Blank video when converting MP4 to AVI DivX
By vidnov in forum ffmpegX general discussionReplies: 16Last Post: 12th Mar 2010, 17:45 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 17:51 -
Converting from VOB to any other format - doesn't keep the original size
By Mylo in forum DVD RippingReplies: 5Last Post: 14th Mar 2009, 13:58
