VideoHelp.com Forum
Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
  1. Member L.A's HiGhEsT's Avatar
    Kay i figured out a easier way to make the samsung (bn-p-1600 blueray player) play avi files or xvid in the U.S.A.. I just downloaded the up to date firmeware from the brasilian website.. Then i changed the RUF file to XAA with that hex program i got in here, then i used a program to put it on ISO image... Then i used Roxio Creator to rip the ISO image to a cd, then i loaded the disc in the blue ray player it read it rite away and it asked if i wanted to up date my firmware and thats it, it just let me have You-Tube noting else, but i dont use that crap its jus to watch movies you know. Now i dont know why sum one did'nt upload the ISO file yet to save every one sum hassle here in the U.S.A. So here it is jus down load it, rip the ISO image with ripping software that can burn ISO image and put on a blank cd and load it in, it will read it whitch takes a couple mins then it will ask you if you want to update with the new firmware and click yes, simple and hassle free, enjoy...Jus download and unpack wit WinRAR.........
    http://www.megaupload.com/?d=FK77NHC2
    Hi, I have a BD P1600 Blu Ray from the USA. I live in Hungary, so I can use it with a voltage converter. It's working well, but I can't unlock it, so I can play only US DVDs and Blu Ray films. It has the newsest firmware, ver.2.18./XAA
    I tried several method:
    1. downloaded Brasil and Singapore, etc... firmwares, modified the firmware with editor (to XAA), but it's not working. Tried to update from USB and from CD...
    2. I tried the unlock codes, not working too...
    I can't play Divx films as well... only mp3 and youtube is working..
    Has anybody got any good idea to solve this problem? I know, the easiest way to change the BD to another one, but I would like to use this one...
    Thanks a lot!!!
    You'll probably never be able to unlock it since you bought it in the USA. Manufacturers make hardware changes all the time and very likely the old firmware change idea simply doesn't work with currently available US hardware. Do note that the firmware change is VERY risky and we've had reports of players getting bricked when people tried to do this. Or it will work but it will then make the player a Brazilian locked player, which is useless to someone in Europe.
    I'm not aware of ANY Sony BluRay player currently sold in the USA/Canada that can be unlocked by ANY method. The ONLY ones I've heard of recently that can be unlocked at all are a very limited number of players sold in other parts of the world, usually Australia.
    Thanks for the answer! At this momment I can use this player only for mp3 and audio CD playing and for Youtube watching... Is there any way to change the firmware for Divx playing? I know, its a very big risk, but now I have an audio player only... so it's not a big risk to try to change the firmware. But I don't know the method... I know, I can't watch European Blu Rays by this anymore... But maybe divx movies... ?
    My firend has a flash/EEPROM programmer machine for different sockets. Maybe he can owerwrite the current US firmware wint the Singapore one, but he needs the installed version for that. Is it possible to download it from any site?
    I actually got the region free to work on my Samsung bd-p1600 region 4 for a couple of american TV series they didn't show in Australia before i upgraded the firmware but that stopped them playing. No matter how many times i tryed i couldn't unlock it again..... Until yesterday when i had my plasma wall mounted and had to set everything back up and thought i will give it one more go.
    I selected the channel for the player. but nothing came up when i turned on the player,
    I then noticed the HDMI cable was out before i turned it on, the player was on at this stage... so i connected the cable with the player on and on the screen it said language selection (which i've never seen this screen before) so i selected English and the the region code 4 was in the top of the corner which is when i frantically had a moment of genius and pushed 9 (region free) now it works .. Woo Hoo!!! none of the annoying codes then hitting the repeat button, Hope this works for someone else as i may sound like a nut and wouldn't believe it myself but psych works now so i can put my old Panasonic away...
    Whats with the codes anyway who could be bothered copying a blue ray when the discs costs more than the movie to buy.
    The original purpose of region codes on DVD was to prevent people from buying a movie in another part of the world before it came to theaters in their part of the world. Hollywood has mostly moved away from that model so now region codes simply exist because Hollywood can't let you have anything without restricting it in some way.
    That's not true that blank BluRay discs cost more than the movie. Well, maybe if you only buy your discs at Frys or some other physical store, but if you buy online the price is substantially lower.
    I see the point for region codes however our local stations start a TV series then either stop it half way through, change the time its on for 2am in the morning without advertising that so you can set it to record or stop it on the season finale... very annoying which wouldn't be so bad if the DVD stores here got it in to buy or rent but it usually takes years to get to Australia. And i don't mind spending money to support movies as i like having the original product. And our local cinemas are well fairly crap and for $15.50 they can at least clean the place.
    and the blank BluRay discs may be cheaper but by the time you download the film, hire it to copy, print a cover it's a lot of trouble to go to instead of waiting for the price of a film to drop to $10. I usually buy three for thirty. & i just brought the back to the future trilogy for $19.95 anyway these days i just chuck movies on a hard drive and watch them, then if there any good buy them. I learnt my lesson buying films strait away as i had 235 original DVDs but traded them for credit a the local video shop, as i found i really don't get time to watch a film twice these days, specially now that Skyrim just came out, oh and those baby things take up alot of time... anyways was just trying to help as i can watch psych again as they took for years to bring seasons 2 & 3 here and just brought season 5 from amazon, maybe they should stop stores exporting if they don't want it released or just release it worldwide all at once. Anyway thanks for your reply have a good Christmas.
    Could any one suggest how to unlock region code for Samsung BD-P 1600 purchased from Sydney. I tried all measures that were posted in video help.
  1. Replies: 12
    Last Post: 15th Apr 2012, 19:32
  2. unlock region code Samsung DVD-VR357?
    By amyfj in forum DVD & Blu-ray Players
    Last Post: 1st May 2011, 08:19
  3. Samsung BD-P1600 source code now available for download
    By ften in forum DVD & Blu-ray Players
    Last Post: 9th Jul 2010, 10:23
  4. Help - Samsung R155 multi region unlock code needed
    By pixie in forum DVD & Blu-ray Players
    Last Post: 8th Aug 2008, 10:33
  5. NEEDED - Unlock Region Code for Samsung DVD-R160
    By Suj in forum DVD & Blu-ray Recorders
    Last Post: 12th Dec 2007, 07:38
