I have a YESS HD DVB-T Terrestrial Decoder (which is a rebadged JC Mathews DVB-T Decoder see http://www.jcmatthew.com) that works as a PVR and allows you to record HDTV to a USB hard drive. I would love to be able to play/convert the stored files to something I can use on my PC. The files stored are
data.idx and Data00.trp (not quite sure what the idx file is
TsRemux recognises the transport stream as an MPEG2 audio stream and an AVC videop stream. If I remux only the video stream only then I can play it with GOM Media player and Super (All others fail such as VLC,Media Player 11 with Transport Stream Control Plugin). If I enclude the audio stream or mux the audio stream only then GOM media player (and everything else) crashed if I tried to play the resulting file. MediaInfo sees the .trp file as
MPEG-TS (No PAT/PMT): 381 MiB, 14mn 56s720*576 (16/9), at 25.000 fps, AVC (Component) (Main@L3.0) (CABAC / 4 Ref Frames)MPEG Audio
I have tried lots of players and converters (HDTVtoMPEG2,tsMuxerGUI,hdtvpump,GordianKnot) with no success
I have all the codecs you can think of installed on my machine. Does anyone have any ideas on the best way forward ??????
Results 1 to 1 of 1
Help !!Convert a trp file with Mpeg streamclip
By caliman in forum Video ConversionReplies: 0Last Post: 21st Oct 2010, 11:55 -
Convert DVB-T MPEG4 H264 stream
By rocka in forum DVB / HDTVReplies: 14Last Post: 5th Aug 2010, 05:12 -
subtitle in trp file
By senderj in forum SubtitleReplies: 1Last Post: 14th Dec 2009, 08:24 -
How to convert avi to trp so I can play it in my viewsonic 360 reciever
By krykson in forum Newbie / General discussionsReplies: 1Last Post: 17th Oct 2009, 16:40 -
Converting MPEG4 .trp to h264 mkv
By Eric10301 in forum Video ConversionReplies: 13Last Post: 15th Jul 2008, 17:32
