I have no idea what to do. Please me. When I mux my subtitles but I keep getting these funny green or white lines. please take a look at my sample to help show you what I mean.
Using what software ?
What format are the subs ?
What is your source video format ?
What is your output video format ?
What is your process ?
software
TMPGEnc 4.0 XPress
to mux subtitles
sub format is
I think is srt
input video format is xvid in an mkv
Output format is mpeg
Process
I use TMPGEnc and just load the mkv and mux subs into an mpeg.
If you have an avi file and are outputting an MKV file, why not just use MKV merge to put the subs in without re-encoding.
I don't want the ouput to be mkv I want the subs to permanent. Is there any way I can just crop it or dose it have to do with the subtitle format or length?
Never mind I fixed it. I just used MKVEWizard and muxed them together from separate audio, video and subtitle using the older version of
TMPGEnc. Thank you for your help. I hope this helps anyone else whit the same problem.
TMPGENC 4.0 Xpress Weird Problem! (Shows Green Bar On Left Side Of Video)
By hypnoticpimp in forum Video ConversionReplies: 16Last Post: 11th Jan 2010, 07:36 -
By hypnoticpimp in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2009, 02:17 -
By hypnoticpimp in forum Authoring (DVD)Replies: 1Last Post: 14th Apr 2009, 09:05 -
blue line on the left side
By themaster1 in forum RestorationReplies: 7Last Post: 26th Jan 2008, 08:03 -
Green subs appears on DVD but even when I rip it, on PC i'ts white!!!
By cemman in forum SubtitleReplies: 3Last Post: 21st Jun 2007, 14:57
