I have been looking at different sites and this question really puzzles me(I'm hoping that in the answer lies the reason why my DVD Player doesn't read my CRDWs, though it says they are supported)
In any case, be it the reason or not, I'm wondering about the VCD sector size. I noticed Nero creates VCDs with 2336 byte sectors. VCDEasy's default is 2352 which is what I've been using (and I have created a lot of VCDs on CD-R media which plays OK on my Aiwa DV170).
So my question is, is 2336 byte sectors more compatible than 2352? VCDEasy allows you to create VCDs with 2336 byte sectors. Should I enable that?
Can anybody tell me based on their experience/knowledge?
Thanks in advance
Results 1 to 1 of 1
danalmsa
how to RIP/COPY dvd with bad sector??
By ysfm in forum DVD RippingReplies: 5Last Post: 25th Feb 2011, 00:00 -
Recommended blank DVD media and recommended media storage methods
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 21:05 -
Start sector question in GEAR PRO
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 22nd Nov 2009, 14:23 -
video size VCD
By Nicksummer in forum VCDEasy GeneralReplies: 3Last Post: 3rd Jun 2008, 08:09 -
How to avoid data burn to bad sector of CD/DVD RW ?
By kclgad in forum MediaReplies: 1Last Post: 31st May 2007, 07:17
