VideoHelp.com Forum
    I have purchased the Pro version of vo2mpg, and love it.... but I was wondering if I could make a feature request for the command line options. I would like to be able to pass the Audio stream id on the command line. I can choose the stream through the UI, but when converting my entire dvd collection (400+ discs) to a media server, it gets rather tedious. The command line options currently available are working great for most of my dvd's, however some of them end up with spanish or french as the default stream when I play it back in any media player.
    Since I'm scripting the conversion, I would like to be able to pass in the audio stream id (found using media info) that I want to remain in the output.
    Is this command line option something we can get added to the pro version soon?
    Thanks for your time!
    You made a great product!
  2. Member ChrissyBoy's Avatar
    Yes this is something i can add quite easily.
    Has there been any progress on this?
  4. Member ChrissyBoy's Avatar
    I have a build you can try.... Please PM me and i will send you it... However i go on holiday tomorrow for a week!
  5. Member ChrissyBoy's Avatar
    Actually this is added in build: 3.0.0060
    Added audio stream selection to command line options (e.g /a=128)[NB: value is in decimal not HEX so 0x80 is 128 in the example].
  1. VOB2MPG PRO command line not processing in 64bit Windows 7
    By BJTHEDJ in forum SVCD2DVD & VOB2MPG
    Last Post: 6th Dec 2010, 15:53
  2. VOB2MPG PRO feature request - subtitle rendering!
    By VideoThug in forum SVCD2DVD & VOB2MPG
    Last Post: 19th Nov 2010, 03:24
  3. VOB2MPG command line problem
    By Toreadore in forum SVCD2DVD & VOB2MPG
    Last Post: 28th Mar 2010, 13:58
  4. Replies: 1
    Last Post: 12th Mar 2010, 18:02
  5. [Feature Request] Please add batch video conversion option!
    By Panarchy in forum ffmpegX general discussion
    Last Post: 20th May 2008, 07:13
