VideoHelp.com Forum
    hi,
    I'm looking for a video tool for mac os x(free if possible) that gives me the possibility to crop 4:3 or 16:9 without unscaling the image that would just add black bars to the video and keep the aspect ratio.
    thing is i wanna burn a video onto dvd but when i use ffmpegx and put it 16:9 720x480 to create a video_ts it screws up the scaling and doesnt crop, it enlages the image to fit the frame.
    my source format is 608x336 but i want it to be full screen on a 16:9 hd tv which is 720x480 with black bars if necessary.
    it could be a tool in a more complete video program or a simple application that does only that.
    i googled and i read many forums but i haven't found a way to do this
    -Frank
    Macbook pro 2.4 Ghz/4Go Ram/ OSX 10.5.7
  2. Explorer Case's Avatar
    Your source file is very close to 16:9. You only need to letterbox 1.7% vertically; that is 8 pixels on a height of 480. Perhaps your source file is 1.7% off, and you don't need to letterbox at all for perfect 16:9.
    1/ Open your source file.
    2/ Set the DVD preset.
    3/ In the Video tab, set Autosize to "DVD 16:9". This will flag the MPEG-2 video to display with a 16:9 aspect ratio, even though the resolution is 720x480.
    4/ If you want to letterbox, do so in the Filters tab, by entering the numbers 4 4 0 0 in the letterbox fields.
    5/ Encode.
  1. Aspect Ratio
    By ping182nz7 in forum Editing
    Last Post: 26th Apr 2010, 13:30
  2. Aspect ratio
    By ngc7088 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 11th Mar 2010, 11:25
  3. 16:10 Aspect Ratio
    By SWBisbee in forum Newbie / General discussions
    Last Post: 31st May 2008, 01:41
  4. Aspect ratio??
    By frednufc in forum Video Conversion
    Last Post: 14th Oct 2007, 15:11
  5. what is aspect ratio?
    By mai_hnf in forum Authoring (VCD/SVCD)
    Last Post: 29th Sep 2007, 22:29
