Hey I am trying to convert files from a JVC Everio HDD GZ-MC 200 to imovie/quicktime (I at least want to be able to watch it on the computer).
First I copied the JVC .mod files to an external drive and then manually changed the extensions to .mpg.
Second I dropped the .mpg files in to ffmpegx and chose to convert to .dv (as this was suggested to be of best quality by someone in one of these forums).
I did all files and I can import/retrieve using imovie, quicktime or just clicking the file and it will play etc however, after about 5/10/15 seconds of 'ok' video and audio play it freezes the video play, chops, stops and starts but then with no audio etc but still shows the time ticking along... So I have cut and paste the error message below...
Oh I also tried the bug troubleshooter of "inverting mapping" because I saw it somewhere and this also caused the same error message.
The other suggestion was to increase the video bitrate but I have no idea how to work out what to increase to in order to enable successful video and audio play.
Encoding started on Thu Jul 30 17:46:05 EST 2009
Input #0, mpeg, from '/Volumes/Public-2/Shared Videos/Mp_Root/101PNV01/PRG001/MOV01E.MPG':
Duration: 00:00:22.6, start: 0.258444, bitrate: 4863 kb/s
Stream #0.0: Video: mpeg2video, 720x576, 25.00 fps
Stream #0.1: Audio: ac3, 48000 Hz, stereo, 256 kb/s
Output #0, dv, to '/Volumes/Public-2/Shared Videos/Mp_Root/101PNV01/PRG001/MOV01E.MPG.ff.dv':
Stream #0.0: Video: dvvideo, 720x576, 25.00 fps, q=2-15, 25000 kb/s
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
[dvvideo @ 0x381324]Can't process DV frame #566. Insufficient audio data or severe sync problem.
video:80859kB audio:4248kB global headers:0kB muxing overhead -6.478434%
bench: utime=29.766s
Encoding completed on Thu Jul 30 17:47:02 EST 2009
CAN ANYONE HELP OR SUGGEST A FIX? I'm very new at all of this so "dumb and dumber" instructions required. Ha Ha
Thanks, Ange
You mentioned that there is a playback problem after you dropped the converted clip into iMovie, but did you try playing the dv file before then? This will help identify where the problem lies.
"Invert mapping" can help only if you get a stream mapping error. It is not a general solution to unknown problems.Originally Posted by carsskee
DV has a fixed bitrate. Do not change it, or the DV file will be invalid.Originally Posted by carsskee
You may also try to convert to DV with MPEG Streamclip, if you can't get it to work with ffmpegX.
audio video sync issues after converting to mpeg with "Burn"
By wsgoogoo in forum MacReplies: 4Last Post: 9th Nov 2010, 19:02 -
"fixed" AVI has audio sync and video blocking problems
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 05:00 -
"data disk" rather than as an "audio disk"?
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 20th Jan 2009, 09:10 -
Nero failure burning "Audio & Data cd"
By spiritgumm in forum AudioReplies: 4Last Post: 15th Oct 2008, 16:25 -
"Data Disc DVD" Audio Problem
By U87 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th Jan 2008, 10:24
Statistics
Newest guides
Latest tool updates
New media comments
