Hello - What do you guys think of MAC MINI for video editing?
Thread: MAC MINI
I wouldn't recommend it for editing.
It has a slow CPU, small hard drive and not much RAM. You might read this review: http://www.macintouch.com/macmini/review.html
I would probably go for a regular PC as you can find several close to the price of a Mac Mini with arguably better features and performance. The higher end Macs may have some advantages, but they can get expensive.
I use a MacBook Pro and a Mini for some tasks, and a generic Windows box for others.
It depends what kind of editing you're talking about: for simple DV camcorder stuff the Mini can be fine. If you want to get fancy with Final Cut Pro and HD video, you'll want a more powerful Mac. Apple seems to have centered itself around the "creating and editing original material today" field: if thats the work you do, a Mac is a great tool (although you might need something stronger than a Mini).
If you primarily want to work with existing poorly-recorded videos, or ripped files from DVD, etc, get a PC: after an early lead, Apple seems to have lost the interest of these types of video software programmers- many more freeware/shareware options are available on Windows. If this kind of work is your primary interest, take a look at the "restoration" forums here and see if the Mac alternatives will suit you (and run well on a Mini). Long-time expert members like LordSmurf use both platforms and often weigh in on the pros and cons.
HDMI Splitter with Mac Mini Help
By Premo in forum Newbie / General discussionsReplies: 0Last Post: 28th Sep 2011, 01:06 -
Mini DV To Mac
By mvtm in forum MacReplies: 20Last Post: 22nd Sep 2011, 23:25 -
Best way to optimize Mac Mini for live broadcasting?
By jbaugh in forum MacReplies: 0Last Post: 29th Dec 2009, 13:26 -
Mac Mini to TV quality?
By whoisquilty in forum MacReplies: 14Last Post: 11th Jan 2009, 10:57 -
Mac Mini - Leopard Memory Req?
By edDV in forum MacReplies: 9Last Post: 3rd Nov 2007, 12:16
Statistics
Newest guides
Latest tool updates
New media comments
