    hi this is my first time posting here at these fine forums. im going to get right to it.
    i have planet earth in 720p, and i use tsMuxer to remux them to m2ts at 4.1 audio channel to be compatible with ps3. i store them in the ps3, the video is superb.
    the problems come when i try remuxing another planet earth video, thats in 1080p, in tsMuxer and do the same process, i then store it in my ps3 but when i try playing it, i am put up with a black screen and only audio. what did i do wrong? it works for 720 video but not 1080? is it the video size? it plays just fine on my pc...
    UPDATE: I made it into a avchd and put it on my flash drive, but i had the same results, black screen with audio. so then, using YAMB, i made it into an mp4 avc. but when i tried playing it, it said its not supported.
    Thanks for all the help, i put the following info below for the 1080p vid thats in m2ts format.
    General
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 4.59 GiB
    Duration : 53mn 24s
    Overall bit rate : 12.3 Mbps
    Maximum Overall bit rate : 35.5 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 16 frames
    Duration : 53mn 24s
    Bit rate : 11.4 Mbps
    Nominal bit rate : 11.3 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16/9
    Frame rate : 23.976 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.228
    Stream size : 4.24 GiB (92%)
    Writing library : x264 core 55 svn-655
    Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=11291 / ratetol=1.5 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.3
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Duration : 53mn 24s
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Surround: L R, LFE
    Sampling rate : 48.0 KHz
    Stream size : 171 MiB (4%)
    Language : English
    it's the number of reference frames.
    the max number of reference frames of Blu-ray 1080p is 4 but your file has 16 ref frames.
    how can i change that? with tsMuxer?
    Look what happended when i tried creating an mp4 with gotsent on the same video.
    so it tells me to re-encode, and i do h264 like it said with now quality loss. i then go to sleep, wake up and it failed.
    UPDATE: so i took your advice yonta, i extracted the video with mkvextract and took the video, using h264info and changed its reference fames to 4 just as you said. then i used tsMuxer and created an m2ts file. It still didnt work, i am put up with a black screen and audio. here is the following properties:
    General
    Format : BDAV
    Duration : 53mn 24s
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format settings, ReFrames : 4 frames
    Duration : 53mn 24s
    Colorimetry : 4:2:0
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Duration : 53mn 24s
    Bit rate : 448 Kbps
    FINAL UPDATE: Success! tried one last time, only this time i used mkv2vob and added the mkv file and it muxed it into m2ts. works beautifully now, the only trick is to transfer it to the ps3 since its more than 4 gig i cant copy it to a flash or hard drive, i am sending it over wiFi via media sharing. it takes a while though.
    I have a question. look below and you will notice that it's profile is main@high while the other videos i muxed were high@4.1 profile. was that the problem? and also i didnt notice a reference frame down there. are there none?
    Format : MPEG-TS
    File size : 4.57 GiB
    Duration : 53mn 21s
    Video
    Menu ID : 1 (0x1)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High
    Format settings, Matrix : Default
    Duration : 53mn 21s
    Bit rate mode : Variable
    Bit rate : 11.0 Mbps
    Nominal bit rate : 40.0 Mbps
    Colorimetry : 4:2:0
    Bits/(Pixel*Frame) : 0.220
    Stream size : 4.08 GiB (89%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Duration : 53mn 21s
    Bit rate : 448 Kbps
    apparently you didn't remux but encoded the whole thing to MPEG2 and repacked it as a transport stream. Long story short, the video is no longer AVC, hence the "reference frame number" don't apply (it's an AVC thing you know...).
    In any case, if you want to use AVC, there's no magic trick to "change the reference frames" as if nothing happened, you're going to have to re-encode the whole thing
    Sorry, I had to go see about a girl
  1. mkv avc profile change for ps3
    By ckamc in forum Video Conversion
    Last Post: 16th Jan 2012, 11:24
  2. Problem with subtitles on PS3 with m2ts
    By Futterama in forum Video Conversion
    Last Post: 16th Oct 2010, 02:59
  3. tsMuxer and joining m2ts files
    By fkasparek in forum Blu-ray Ripping
    Last Post: 22nd Jun 2009, 21:31
  4. Problem converting mkv to m2ts (for PS3)
    By scift in forum Video Conversion
    Last Post: 16th Dec 2008, 18:22
  5. AVC/h264 1080p mkv macroblock problem on sequence transition
    By djesteban in forum Blu-ray Ripping
    Last Post: 7th Oct 2008, 10:18
About   Advertise   Forum   RSS Feeds   Statistics   Tools
