VideoHelp.com Forum
  1. I have an AVI file with 5.1 DTS Audio - is there a program that can convert the audio?
    for e.g. like Popcorn MKV Audio Converter does it to 10Gb MKV's in about 30mins
    thanks
    EDIT: ive tried AVIDEMUX as i thought that may work but upon opening the AVI file it says NO AUDIO DECODER FOUND FOR THIS FILE - SAVING VIDEO+AUDIO WILL RESULT IN BAD AVI
  2. use gspot and mediainfo to see what codec the audio uses. sounds like avidemux thinks you don't have the proper codec.
  3. audio is DTS 5.1
    video is AVI (1280x720)
    You might try eac3to, but I don't know if it can accept AVI input. You may have to demux the audio and then convert that. Various tools like BeSweet or eac3to should be able to convert your DTS audio to AC3.
  5. Originally Posted by snadge
    audio is DTS 5.1
    yes but gspot will tell you if your computer has a codec to allow conversion. and "avi" is meaningless, it the name of a container, not a video type. it could be rgb, DVavi, divx, or any of a hundred others.
  1. I have a problem, player cant play DTS... need to convert
    By Chrushev in forum Authoring (DVD)
    Last Post: 25th Oct 2009, 02:56
  2. DTS wont play through amp
    By Bazza-61 in forum Audio
    Last Post: 24th Sep 2009, 09:54
  3. Play/Convert .DTS??
    By merciscool in forum Mac
    Last Post: 24th Aug 2009, 14:24
  4. Replies: 13
    Last Post: 10th Mar 2009, 13:58
  5. DVD Player wont play DTS 6Ch, can i change Audio?
    By snadge in forum Newbie / General discussions
    Last Post: 16th Jan 2008, 06:12
