VideoHelp.com Forum
    Hi all,
    I always use subtitle workshop whenever I need to sync a subtitle (.srt) file with the MKV I have. But now, I am trying to do the same with a .m2ts file in subtitle workshop, only the video doesnt want to play. I can load the subtitle but there's no way I can start the video.
    I have the K-Lite codec pack installed on my computer. Media Player Classic has no problems playing the file, but I cannot get the movie to play in VLC media player either.. Might there be some codec I have to configure in a different way, or just one I need to add in order to make it work?
    Btw ; still running on Windows XP
    Any other recommendations on how to sync an m2ts file with .srt subs are welcome as well
    Thanks for your time.
    VLC has builtin codecs so you can't adjust any codec.
    Are you using latest vlc 1.0.1 ?
    Does the audio play? or nothing? any errors?
    Using 1.0.1, check.
    Audio doesnt play, video doesnt play, I can use the pauze & play buttons but nothing start, not even a counter...
  1. Problems playing 1080p files on VLC player
    By Tafflad in forum Newbie / General discussions
    Last Post: 20th Oct 2011, 16:29
  2. No audio playing M2TS files with Windows Media Player
    By majouz in forum Software Playing
    Last Post: 20th Jun 2011, 14:25
  3. Replies: 4
    Last Post: 1st Aug 2008, 22:49
  4. VLC Media Player subtitle font
    By ecc in forum Subtitle
    Last Post: 30th May 2008, 06:12
  5. VCD problems (playing using VLC; no menus in Media Player)
    By pwhyles in forum Newbie / General discussions
    Last Post: 17th Jan 2008, 13:16
