Here's my setup.
50" Samsung HDTV
HP Paviolion dv3510nr laptop.
Not sure what is happening. When I hook up my laptop to my TV through the HDMI cable, I get no sound. I do, however, get video. The video works fine, just not audio whatsoever through the TV. The audio will only play through my laptop speakers.
I did some research, and saw that you're supposed to go into the "Sound" portion of the control panel. I go there and click "Playback." This is where I'm supposed to set the default to HDMI. However, HDMI isn't an option.
The only options are "Speakers and dual headphones" (the default now), "Independent dual headphones" and SPDIF (Digital out Via HP Dock).
I've tried setting all of these as the default, and the audio still only plays through the stereo speakers.
I know the problem isn't the TV -- my roommate can get audio playback through his laptop on the same TV. Also, I tried another HDMI cable with my laptop -- No dice. I also tried another TV with both cables -- no dice.
Not sure what's going wrong. I have a NVidia graphics card, and there is no option in the sound settings to set HDMI as default.
Please help.....
Best to call your laptop tech support or ask in a support forum for that particular laptop.
http://www.kiva.org/about -
some laptops need the audio out set to spdif to send over hdmi.
What is the graphics card?
You might need http://www.nvidia.com/object/nforce_hdmi_audio_winxp_1.00.0.37.html
(but I guess it should be installed if you install the complete nvidia drivers) -
Depends ... assuming vista, then follow the hdmi audio setup part > http://www1.sapphiretech.com/us/productfiles/Catalogue_HDMI_Sound_output.pdf (443kb)
Control panel > system > device manager (clasic view)
Control panel > System and Maintenance > device manager (standard view)
Check for "?" devices and install device drivers ... or update hdmi audio drivers from hp support.
Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 16:33 -
HDMI Cable - Audio ???
By blinky88 in forum ComputerReplies: 8Last Post: 27th Apr 2011, 07:23 -
Suddenly no audio with HDMI cable
By StarDweller in forum DVD & Blu-ray PlayersReplies: 15Last Post: 14th May 2010, 10:45 -
audio with hdmi cable?
By eligen in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2009, 00:35 -
Problem hooking up my laptop to my new samsung tv via hdmi...
By theone4355 in forum Newbie / General discussionsReplies: 0Last Post: 21st Dec 2008, 22:47
