VideoHelp.com Forum
  1. hi there,
    i have captured National Treasure from bbc hd using my hd pvr and it clocks in at 8gb.
    when i go to create an avchd using either total media theatre or power producer the size swells to over 10gb,presumably because of the menu.
    can someone please recommend a program that will do this without a menu so i can put on an 8.5gb dvd.
    many thanks.
  3. quick and succinct ,
    i thank you!
  4. hi my file is in mt2s format.
    tsmuxer says unsupported format and multiavchd imports fine but then displays the error does not contain any titles.
    it produces a file with no video even though it showed up as 8gb initially.
    any ideas?
  5. Enable [x] Verbose logging in Settings and post your log - otherwise it is hard to get help.
    Laugh and the world will laugh with you. Cry and you will be alone
    Total Media Extreme will burn avchd without a menu. Just tick the box when you go to produce and burn the movie.
    Have you ever done this successfully before from a file you recorded with your PVR? I don't know about the UK, but here in the USA all or almost all of the PVRs use proprietary formats when recording. It ranges from difficult to impossible, depending on which PVR is used, to get the video into some other format from the hard disk.
    Yes. I use a Hauppauge HD PVR to get recordings off my ATT Uverse DVR.
  1. Replies: 5
    Last Post: 29th Aug 2011, 11:49
  2. AVCHD on hard drive: creating new AVCHD folder structure
    By Phil_W in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 1st May 2011, 14:46
  3. software to batch convert m2ts format avchd to mts avchd?
    By masterpug in forum Video Conversion
    Last Post: 14th Aug 2010, 01:06
  4. Author AVCHD with simple text-based menu?
    By litmus in forum Authoring (Blu-ray)
    Last Post: 28th Feb 2010, 17:52
  5. How to create IFO &BUP file for DVD menu[have menu vob]
    By Aliyans in forum Authoring (DVD)
    Last Post: 28th Dec 2007, 11:36
