VideoHelp.com Forum
  1. Banned
    Hello
    I need to capture in video the screen of another notebook computer to be able to mixer of video since another notebook computer.
    Some suggestion?
    Which it is the best solution to capture the sign of another notebook computer (PC)?
    The sign of screen can be taken by...
    - Firewire? (IE1394)?
    - LAN?
    - VGA video (transcoder)?
    Lic. Fernando Pérez Cardenal
    . : Digital Marketing - Digital Videos - Multimedia:.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    From the laptop itself, you could use CamStudio or Fraps or one of the other screen capture programs here: http://www.videohelp.com/tools/secti...screen-capture
    If you need to capture the video output of the laptop, it depends on what usable outputs it has. Likely only composite, then you could try a capture card or device on the second computer. But the screen capture method would probably be better.
    If it does have VGA or FireWire out, FireWire would be my choice of the two if you have a FireWire device you can capture it to. Maybe a camcorder. But I think it would have to be a DV-AVI compliant output from the laptop.
    You may also be able to stream the video over a LAN, and then I would look into VLC media player for it's streaming abilities. Probably other programs could do this also.
  1. Replies: 19
    Last Post: 19th Sep 2009, 04:55
  2. Going from desktop to notebook
    By Caple in forum Computer
    Last Post: 19th Aug 2009, 10:55
  3. Capture Desktop screen on a streaming format?
    By therock003 in forum Video Streaming
    Last Post: 9th Feb 2009, 13:24
  4. What program can I used to Capture what i'm doing on the desktop (monitor)?
    By Goldman123 in forum Newbie / General discussions
    Last Post: 27th May 2008, 14:02
  5. Is there a software that i can Capture my Desktop Actions?
    By hgtvg in forum Newbie / General discussions
    Last Post: 22nd May 2007, 19:10
