VideoHelp.com Forum
Results 1 to 14 of 14
    my player cannot seem to play mp4 movies. do i need to convert this to a different format inorder to be able to play it ?
    thanks
    Yes, you need to convert them. Exactly what you need to do depends on what you mean by "mp4 movies". The Philips 5990 likes Divx/Xvid with AC3 or MP3 audio in an AVI container. You could always make regular movie DVDs too.
    Post what MediaInfo says about your videos.
    it's a x.264 encoded video in an MP4 file
    The 5990 can't read the MP4 container and can't decode h.264 video. You probably have AAC audio which it also can't decode.
    You can try converting with Xvid4PSP, AviDemux, VirtualDub...
    thanks!
  6. VH Wanderer Ai Haibara's Avatar
    The 5990 can recognize and play .mp4 files (you'll notice they do show up on the 5990's browser) - however, the MP4 videos generally have to be DivX/Xvid video streams with an MP3 audio stream. In other words, basically whatever the 5990 will play in AVI/.divx format, just remuxed into the MP4 container.
    The only advantage with playing those sorts of MP4s through the 5990 is, in my opinion, that the 5990 won't do the little 'index' bit before playing an MP4. But since it's not really that much of a hassle, anyway...
    (Edit: forgot to mention that it'll also properly recognize AVIs renamed to .mp4, as well.)
    Originally Posted by Ai Haibara
    The 5990 can recognize and play .mp4 files...
    You're right. I keep forgetting that. And yes, only the same codecs that it plays in AVI will play in MP4.
    I have a bunch of mp4s I'de like to play on the 5990. When I play them, I get sound but no video and i see a message saying "codec not support"...or something to that affect. Whats my best option? To convert the files to avi? Below is some information on one of the files from MediaInfo.
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 49.4 MiB
    Duration : 13mn 10s
    Overall bit rate : 524 Kbps
    Encoded date : UTC 2008-07-27 19:47:06
    Tagged date : UTC 2008-07-27 20:34:09
    MP42 is a very old Microsoft MPEG 4 part 2 codec. The Philips players do no play it. You'll have to convert to Divx/Xvid.
  10. Member wulf109's Avatar
    I make mp4's with Nero Recode and my 5990 plays them. What does Recode use as audio?
    Use GSpot or MediaInfo to find out.
    Are there any free programs available that will convert mp4 to divx/xvid?
  13. Member MJA's Avatar
    StaxRip or VirtualDubMod both are free
  1. Need to convert to mp4 with these specifications (Philips Gogear Vibe)
    By alx1880 in forum Newbie / General discussions
    Last Post: 15th Feb 2012, 16:56
  2. Philips DVP5990/37 and mp4 video
    By rogmath in forum DVD & Blu-ray Players
    Last Post: 21st Nov 2010, 18:06
  3. loop mp4 or avi locally so will play on mp4 player - ?
    By marinebc11 in forum Video Conversion
    Last Post: 3rd Oct 2010, 20:24
  4. MKV to MP4 for Philips TV
    By staljin in forum Video Conversion
    Last Post: 24th Jun 2009, 08:45
  5. How do I play/convert .MP4 files to play on my laptop
    By tfoster in forum Newbie / General discussions
    Last Post: 25th Jul 2008, 20:23
