Using papa john's profiles of 1920x1080 and 1280x720 and digital pictures with 16x9 A/R, the resulting slideshow is stretched wider with black borders on top and bottom(letter-box). I was hoping that it would fill the screen of my HDTV. Is there a setting that I should know about? If I crop my pictures then Photostory's default A/R of 4:3 is displayed correctly. Then the HDTV has borders on the left and right.
My goal is to create a wide screen HD slideshow using AVCHD to be played in my Blu-Ray machine
The outputs have black bars after coming out of photostory, or after further conversion ?
Right after the PhotoStory.Originally Posted by guns1inger
Like I said, if the pictures are cropped to 4x3 A/R, Windows Media player displays the A/R correctly but for a widescreen monitor, I do not want to crop my 9x6 pictures. What it is doing to my 16x9 pictures is, the people look fatter.
Thanks.
The following is taken from papa John's website, just two lines up the page from where you downloaded the templates
If you go to the Import pictures page you will find the follow regarding 16:9 outputIf you use the widescreen profiles... be sure to resize the images you use in the story before you import them, or the video shape won't look right in the Windows Media Player. See the Photo Story 3 > Import Pictures page.
Photo Story can be tricked into making widescreen 16:9 aspect ratio stories by using a custom profile.
The trick is to deliberately distort your images before importing... multiply their width in pixels by .75117 (if your resizing app doesn't handle the extra precision, using 75% is close enough).... or their height by 1.3313 (133.13% for higher quality but larger file sizes). Leave the other dimension as is. They'll look kind of squeezed as you work on them in PS3, because you can only work in the standard 4:3 view... but the saved story will look fine.
It worked! Thanks for researching that for me. Most of my pictures are 4000x2256 so I will have to change the height to 3000. I should have but never thought of that trick(silly me) because I was confident that Papa John's profile will take care of everything.Originally Posted by guns1inger
Now I have to figure out why my XP computer(3Ghz P4, 1GB RAM) with ample storage space is displaying "not enough storage" when doing the 1920x1080 profile for a 5-picture test movie. It does 1280x720 though. Thanks again.
Wrong aspect ratio on TV: could 'Autoformat' cause it?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2010, 01:34 -
Wrong Aspect Ratio
By weathervane in forum CapturingReplies: 11Last Post: 18th Aug 2010, 22:18 -
wrong aspect ratio using ripbot
By magmo in forum Video ConversionReplies: 2Last Post: 12th Mar 2009, 08:15 -
Fixing wrong aspect ratio.
By mattstan in forum Authoring (DVD)Replies: 3Last Post: 8th May 2008, 14:17 -
wrong aspect ratio ???
By clickit in forum ComputerReplies: 3Last Post: 7th Dec 2007, 02:49
