Rather than shoehorn it into this thread
http://forum.videohelp.com/topic367448-30.html#1989806
or some other one, I'm breaking this out as a separate query.
Low profile, as in very unobtrusive, not easy to spot ? I'm thinking in terms of a location that may not have any evident roof-mounted antennas (at least that I recall noticing), perhaps due to CC&Rs of the development ? Just wanted to see what options may exist, if any. Price level is Open.
[Yeah, I know all about that over-riding FCC directive, on consumers not being inhibited in regard to how they choose to pull in signal. It is Federal, and trumps anything state or local. However, I've lived for the last several years in a place where the landlord threatened eviction if you tried to mount anything on the roof. This is illegal, and the tenant would win this if it went to court, but not many are up for waging non-essential battles like this one.]
Results 1 to 14 of 14
When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
as a tenant you are not allowed to make any changes that the owner forbids. you would lose that case. you can only install an antenna in the area that you have exclusive control over.
OTARD rules do not apply to common areas that are owned by a landlord, a community association, or jointly by condominium owners. These common areas may include the roof or exterior walls of a multiple dwelling unit.
I think there may be some variance regarding how it was done. Drilling into the roof, or other lasting changes -- you're probably right. However, I was told that there are ways to do an install that are temporary and reversible, such as a clamp that attaches a small dish to a back balcony railing. Or on a pole or adjacent tree. At one time, I actually read through those 15 or so pages of the FCC ruling, highlighting sections in yellow. I'm quite sure that it did not exclude those leasing an apt. or condo. That would defeat the whole point of it.Originally Posted by minidv2dvd
Anyway, my original question hypothesizes a purchase, rather than a lease, and I'd still like to know if there are any such roof antennas that could go all but unnoticed.When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
Choice of antenna depends on signal strength at your location. Best plot of available channels and their direction is provided by TVfool.com. Enter your address and it generates the plot. You can post it here (address isn't shown)and we can recommend an antenna.
http://www.tvfool.com/?option=com_wrapper&Itemid=29Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Thanks.Originally Posted by edDV
At this point, there are still a few location candidates . . . but we can start with these:
http://www.tvfool.com/?option=com_wr...582f3e4bf19efe
http://www.tvfool.com/?option=com_wr...582fe4dd76e37f
They each cover additional possibilities, within a few blocks radius. Hopefully, the topography
won't vary too much, as between the locations for each.
To reprise, I think any antenna possibility would have to come as close to going unnoticed as possible.When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
google the Slinky antenna
Thanks, I will check that out.Originally Posted by ahhaa
Was wondering what ever happened to edDV, after I posted the info he requested, but I've been so swamped lately I did not get around to bumping the topic, even this late.When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
Sorry, I didn't see this when you posted the plots.
First observation, you have two VHF primary stations (ABC and CBS). These will require a VHF antenna but are strong. A rabbit ears may work. The rest are UHF.
Second observation, you do not have line of sight to the transmitters for any of the stations for 92121. 2Edge means two separate hills or ridges block the path as shown here for NBC (click on call letters for other stations)
http://www.tvfool.com/?option=com_wr...dALLTV%26n%3d6
The 91230 location has direct line of sight to the two VHF stations @ only 6 miles so reception should be easy or too strong. The others are behind a single hill.
Third observation, the two VHF stations are located in a different direction from the UHF for both locations. For this reason, a single VHF/UHF antenna is less likely to work especially at 92121.
So for 91230, I'd first try to get the two VHF stations (8 and 10) with a rabbit ears or dipole from inside. If that works, try a directional UHF similar to this one from inside or attic pointed 120 degrees. This may work for both UHF and VHF because your VHF signals are so strong.
http://www.summitsource.com/winegard...em-p-6536.html
92121 will be more difficult. I think you will need two antennas and a combiner. You will need to get up near the roof with something like these for UHF pointed 130 degrees
http://www.summitsource.com/antennac...70-p-6136.html
http://www.summitsource.com/direct-y...le-p-9231.html
VHF will require something directional like this pointed 190 degrees.
http://www.summitsource.com/6-elemen...acturers_id=11
Combiner
http://www.summitsource.com/2-way-sp...20-p-5276.html
Avoid the temptation to use amplifiers. You are in a valley with medium strong signals and many reflected "multi-path" bounces. Your goal is to isolate the direct stable signal from the bounced signals that will come and go with weather and temperature. The best way to do this is with directional antennas.
If you mount in an attic, larger antennas may be required. Composite shingles cut signal strength ~ 50%.Recommends: Kiva.org - Loans that change lives.
edDV, Thanks for your detailed analysis of that data. It remains to be seen what sort of attic may apply here. (One that is really accessible, or not.) In either case, I would be leery of adding any extra electrical gear up there. The roof material is apt to be clay tiles, which I'm going to guess amounts to even more of a cut in signal strength. And I don't know what may be allowed by way of a roof mount. Antennas on the roof seem to be very much a rarity in these areas, perhaps due to CC&Rs.Originally Posted by edDV
[For any of our non-U.S. readers -- who may or may not have to deal with such local issues -- that stands for "Codes, Covenants, and Restrictions." It's the same idea as not being allowed to paint the side of your house in a dayglo likeness of Bozo the Clown, because that would tend to harm your neighbors' property values.]When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
There is an FCC mandate that overrules any "Codes, Covenants, and Restrictions" for TV reception but you should have options to keep the profile low. Check out how others are dealing with it or demand free cable from the association.Originally Posted by Seeker47Recommends: Kiva.org - Loans that change lives.
Just out of curiosity, have you (or anyone else reading this) seen this deviceOriginally Posted by edDV
http://www.datoptic.com/cgi-bin/web....-49&detail=yes
as a possible indoor solution where signals are strong and line of sight is good ?
I would not want to draw any conclusions from my prior situation, which was very different from either of the ones presented in this thread, but -- for that -- my sampling of various indoor antennas (amplified or not) had rather poor results. Another location with a different device, might be a different story.When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
What makes you think this will work? Google shows no positive reviews. This DAT Optic copy says " all the band of DTV(Digital HDTV)" where other sites say it is UHF (450-870MHz) only. BTW the current UHF TV band is only 470-699 MHz so this must be an old design.
There is no explanation of why it should work or even if it works.Recommends: Kiva.org - Loans that change lives.
Well, I was very skeptical. They claimed to be using it for this demo I saw, which was in a hangar-sized space where the building had a lot of concrete.Originally Posted by edDV
The demo was actually for a whole system, but mainly for their "Media Center replacement" device, which I inquired about in another thread. I know what I saw in the demo (the pretty good image quality), but not really how they were getting it, which could have been almost anything. This casts all of it into doubt, and possibly into the flimflam category.Originally Posted by edDVWhen in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
DTV image quality is a given. Reception problems show as intermittent reception or artifacts from the tuner-decoder as it sorts out multi-path. Bad reception in strong signal areas isn't improved by amplification. You must reject multi-path with directional antennas pointed to the source.
Fringe reception requires directional antennas and sometimes mast mounted amplification.
VHF Ch7-13 (175 - 216 MHz) require different antenna designs vs. UHF Ch 14-51 (470-699 MHz).Recommends: Kiva.org - Loans that change lives.
HDTV antenna questions... again.
By Ai Haibara in forum DVB / HDTVReplies: 32Last Post: 14th Jan 2011, 23:05 -
Do you need to have a "hdtv" antenna for good digital reception?
By yoda313 in forum CapturingReplies: 3Last Post: 8th May 2010, 07:50 -
Anyone here ever make and/or try out a homebrew HDTV Antenna?
By Frank-0-Video in forum DVB / HDTVReplies: 17Last Post: 7th Feb 2009, 19:07 -
Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?
By pianopeddler in forum DVB / HDTVReplies: 2Last Post: 6th Aug 2008, 21:43 -
i'm having problems with hdtv antenna...
By strizzle in forum DVB / HDTVReplies: 4Last Post: 31st Oct 2007, 09:38
