I'm looking for a way to copy shows I've already recorded to my laptop so that I can burn them to dvd and free up some room on the DVR. I have AT&T U-verse, and they tell me there's no way to do it.
The DVR is a Motorola VP1216.
I read this thread but had trouble following the many conversations.
https://forum.videohelp.com/topic361149.html
But what I got from it is that I can purchase a USB capture device to link the DVR and my laptop, then transfer the files that way. Is that correct?
I realize some shows will have some sort of encryption and can't be transferred, but I'm mostly talking about shows that air on free channels (as opposed to HBO, etc.)
BillieJean
The best device going right now is the "Hauppauge HD PVR" $204.00 out the door at NewEgg. It captures right from the Uverse DVR in SD modes and High Def modes. Comes with everything you need to do the job, including the software. Be forwarned that HD editing and burning takes some serious horsepower under the hood. Computer details in your profile leave an awful lot to be desired.
Reelman472 -
Reelman472
So the USB capture device would not work or is just not the best option?
The computer is a Sager notebook with a hard drive that was literally replaced two weeks ago. This computer has Windows XP. (Vista is in my profile because my other computer has it, but the Sager is the one prepped for online gaming, etc.)
I looked up the specifics in the system properties:
Intel(R) Pentium(R) M processor 1.73 GHz
794 MHz, 1.00 GB of RAM
Will that suffice? -
BillieJean,
Your computer specs are far below minimum requirements for that device. Perhaps there is another solution to capture SD video with your rig. Perhaps a usb tuner card hooked to the uverse dvr via coaxial cable might work but I have no idea.
Reelman472
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Help - Transferring encrypted films from DVR box to PC
By maverick777 in forum DVB / IPTVReplies: 4Last Post: 26th Feb 2011, 15:42 -
Beginner needs help transferring DVR recording to computer
By kimatthedock in forum DVB / IPTVReplies: 1Last Post: 30th Aug 2009, 21:37 -
Transferring from a DirecTV DVR to Computer?
By Hangrumps in forum CapturingReplies: 0Last Post: 19th Dec 2008, 13:26 -
Question about transferring HD-DVR to DVD connections
By kevin75 in forum DVB / IPTVReplies: 1Last Post: 29th Apr 2008, 13:03
