VideoHelp.com Forum
    I've been looking for solutions to getting my movie to encode with subs (JCVD) I found one fix so far where I had to take out a bunch of weird characters out of the title, but now I get this new error:
    Encoding started on Fri Jul 24 12:25:12 PDT 2009
    MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
    Mac OSX static build for ffmpegX
    FIXME:Hardenabling SSE and SSE2 without detection
    CPU: Intel (Family: 6, Stepping: 10)
    CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
    Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
    Exiting... (No output file specified, please see the -o option)
    i don't get it, I set the name of where it should be outputted to and everything, what's going on?
    I originally posted in the bug forum and a dude told me to post here, he also told me i didn't specify the output format. Which is weird because the output format is divx mencoder by default, I tried a few others (like divx mmpeg) and it would actually start encoding it, but the only stupid thing is there is no option to vob subtitles in - which is the only reason why I'm doing this.
  2. Explorer Case's Avatar
    Are you converting from a VIDEO_TS folder on your harddisk?
    Are you trying to convert to DivX or XviD?
    Is anything listed in the Save As field before you hit Encode?
    Is the output location writable? (i.e. not a read-only volume)
    Make sure the output location is BSD-Unix-friendly on characters. No spaces or 'special' characters in the path (volume name/folder names/filename). [A file "aaa" on the Desktop should always be safe.] No need to specify a suffix, as ffmpegX will add one (unless the specified one matches what ffmpegX would add).
  1. Replies: 1
    Last Post: 26th Feb 2012, 07:04
  2. Output file is way bigger than input file in Virtualdub
    By sasuweh in forum Video Conversion
    Last Post: 26th Jan 2011, 15:00
  3. Have HD MKV file, would like HD output file
    By StevoK in forum Video Conversion
    Last Post: 9th Feb 2010, 21:43
  4. Output 4:3 file to 16:9
    By waldodiodio in forum Newbie / General discussions
    Last Post: 1st Nov 2009, 11:38
  5. No file after encoding (No output file specified)
    By Bizbo in forum ffmpegX bugs and suggestions
    Last Post: 24th Jul 2009, 20:24
