How do i open multiple files in ffmpegX?
at the moment i don't have any way to join clips together
I want to do the following:-
1. select 6 files
2. open with FFMPEGX
3. then encode and get a single file output
I stumbled on "Tshed" , but wasn't sure if it could be any help?
thank You for ANY help (Appologies, I am a novice)
Thread: open Multiple files
ffmpegX has a Join tool, in the Tools tab, to (attempt to) join m1v, m2v, mpg or avi files.
Joining files can lead to other problems (glitches, sync loss, etc). So if you tell us about your source files and your end goal, perhaps there is a better way to achieve that goal.
1. I did find the Join tool (as you say) but it looked like it only joined 2 clips (NOT 6)
I'm the one with the MOD files codec (a type of MPEG2 codec)....
CASE you have already solved my problem of no Audio by changing the .MOD extension to .VOB
2. the end goal is .mp4 container in the x.264 format
& 1 single file
The join tool will work on a pair of files at a time. Here, you will need to perform five total join operations to complete the job.Originally Posted by waynerrr
Remove multiple tracks from multiple MKV files
By accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 11:50 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
How to Open DVR Files?
By devilcoelhodog in forum Newbie / General discussionsReplies: 9Last Post: 4th Nov 2010, 11:20 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28
Statistics
Newest guides
Latest tool updates
New media comments
