I want to create high quality DVD. I export as 1080i 30p. What kind of setting should I use in premiere pro if I export as 264h quicktime format??
dvd as in dvd that plays on a standard dvd standalone player? if so you can only encode to mpeg-2 720x480.
If you intend to make a real DVD that will play in a DVD player you need to do several steps.
Set up a 1440x1080p 29.97fps custom template.
Import and edit your clips
Resize to 720x480p, 29.97fps
Encode to 720x480i, 29.97fps
Author your DVD.
Quicktime h.264 is not playable on a DVD player.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
"1080i 30p" which is it - interlaced or progressive? you list both.
I think he means 30p mode which is sent as separate fields and appears as 1080i when sent through IEEE-1394. This is normal since 30p is not directly supported. It must be disguised as 1080i. Similar dance for telecined 24p.
yeah i know. i have an hv30 and shoot 30p. in order to use it you have to have an editor that you can change the .m2t file properties in, like vegas, premiere or squeeze. at least i don't have to inverse telecine the 30p like i do with the 24p before using.
Canon Rebel xti + Canon HV30 vs. Canon Rebel T2i
By assman24 in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 17th Jun 2010, 11:47 -
HDV Capture from Canon HV30 to Premeire Pro CS4
By fzf5bl in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 24th Nov 2009, 09:48 -
canon hv30 to cimputer
By gilgeva1 in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 29th Apr 2009, 11:54 -
Canon HV30 / DVD Recorder compatibility
By davideck in forum DVD & Blu-ray RecordersReplies: 4Last Post: 18th Jun 2008, 19:39 -
Going from premiere 1.5 Pro to CS3 Pro - Working with a new Canon HV-20
By Tumbo in forum Newbie / General discussionsReplies: 26Last Post: 24th Apr 2008, 16:25
