VideoHelp.com Forum
    Are I-Frames the same as Keyframes when using the H264 codec?
    Is 300 a satisfactory setting?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Yes. 'I frame' is the proper term, but same as a keyframe. 300 I frame spacing is the same as Xvid/Divx uses by default, so should be OK, though I'm not sure about that. You can look up 'P, I, B' frames in our Glossary for more info.
  3. h264 has a range you should stay in - minimum=framerate maximum=10 x framerate. the smaller the number used the larger the file size.
  4. Member Flarch's Avatar
    Doesn't 'I-Frame' frequency dictate how finely one can skip forward or back?
    Or is that not the case with newer video formats?
    It depends on the playback software/device. Some will skip to the I frame nearest the selected location. Others will skip to the I frame before the selected location, decode all the frames in between, the start displaying at the selected frame. That can take a while with long GOPs, especially with large frame sizes. I usually use I frame intervals of 100 in Divx/Xvid for faster seeking on players that seek to the exact frame.
  1. Total keyframes?
    By anonymous_whatever in forum Newbie / General discussions
    Last Post: 12th Feb 2012, 10:33
  2. Listing keyframes
    By Misterer in forum Newbie / General discussions
    Last Post: 14th Aug 2010, 10:36
  3. Are variable keyframes possible?
    By x2x3x2 in forum Video Conversion
    Last Post: 7th Aug 2010, 07:40
  4. Increase the density of keyframes
    By Stasik0 in forum Editing
    Last Post: 6th Jul 2010, 07:15
  5. changing keyframes in SUPER
    By uglijimus in forum Video Conversion
    Last Post: 16th Jul 2009, 12:39
