The subject should say enough.
I'm really lost in this demuxing stuff, so I'd be super-grateful if someone has a simple solution that HAS worked for him for these exact problem.
I have .mpg files with mpeg II video and AC3 5.1 audio (48kHz 16bit). I'd like to get the center channel of the audio, de-noise it in audio editor and put it back in video (I only need mono, since it's going on the web.)
As far as audio de-noising and putting it all back together, there shouldn't be any problems (or I hope so). For now I just can't seem to get a normal mono wave of the center speaker.
I get ac3 files with ReJig, but converting them with Hyper cube seems to mess up sample rate, since wave is then on super speed (like 3 times faster).
Video Lan VLC doesn't convert to wave (or anything similar)
No results with VidrualDub (including ac3 plugin) or importing in Audacity either.
Any suggestions on how to demux to single mono files from mpg files, or what (preferably freeware) software to use, is greatly appreciated.
Thread: mpg -> AC3 -> mono wave files.
The act of demuxing does not fundamentally change either file. You do not demux to a mono wav file, you demux to an mpg video and an ac3 audio file. Then you use an audio converter to change the ac3 to 6 mono wave files. Two seperate actions.
Besweet with a GUI is excellent for this last step. Lots of ways to demux, just make sure that seperating the audio and video is all the prog is doing. No sample rate conversion should be happening.
Use HeadAC3he to convert the AC3 to wave, using whichever channels you want.
Click on "Options" to see the channel selection.
Just ignore it if it nags you about a Vorbis plugin, you don't need it.
AC3 2.0 on DVD, really mono?
By oscarm in forum AudioReplies: 7Last Post: 22nd Dec 2008, 07:34 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
audio levels keep changing, 5.1 ac3-to-wave
By spiritgumm in forum AudioReplies: 0Last Post: 22nd Mar 2008, 09:56 -
how to: add 2 mono tracks = 2 channel wave?
By spiritgumm in forum AudioReplies: 4Last Post: 7th Sep 2007, 16:52 -
AC3 mono to AC3 2 channel conversion help
By efiste2 in forum AudioReplies: 1Last Post: 21st Jul 2007, 13:06
Statistics
Newest guides
Latest tool updates
New media comments
